IBMobile
Staff
Everything posted by IBMobile
  1. Sounds like it maybe a tire balance problem.
  2. Thank for the heads up. Good find!
  3. Glad you found it. I've heard of speed sensors going bad, but this is the first time hearing that one broke off.
  4. Which "cumminsforum" are you enquiring about?
  5. Check the wires/connector at the speed sensor in the differential and the wires/connector between the cab and the bed to start with. If they are ok then then look at the abs controller.
  6. Try this site. https://tiresize.com/gear-ratio-calculator/
  7. You changed to an Edge EZ and the code still comes on as soon as the key is turned then the problem must likely is with map sensor or wires/connector. Try plugging in a map sensor without installing it and see if the code comes on without starting the engine.
  8. Does this code come back as soon as you turn the key to on or do you have to drive it and generate boost over 19-20 PSI?
  9. The factory heat exchanger not only cools transmission fluid, but all so heats the fluid to operating temperature in cold weather. With the average winter low temperature of 9°F in your area it would be prudent to retain the heat exchanger for winter drivability.
  10. For heat shielding projects I use the heat shielding that car manufacturers use between the car body and the catalytic convertor. I can get it for next to nothing at a junk yard. It is made with up to seven layers of very thin aluminum sandwich between two thicker outer layers. It is very easy to bend and cut to fit or wrap.
  11. If you don't have a coolant system pressure tester of your own, you can "rent" one from Oreilly auto parts store. You'll have to pay for it first then you have 2 days to use it and bring it back for a full refund. I've "rented" several of their tools over the years with no problems. https://www.oreillyauto.com/detail/c/evertough/tools---equipment/rental-tools/air-conditioning---cooling-rental-tools/12095d53bcad/rental-tools-evertough-radiator-and-cap-test-kit/ren1/67085
  12. That is the size, 12⅜" X 8½", I have on my truck. Here is a link to comparative size data for BHAF in the 24 valve 2ed gen, engine air and exhaust section. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/air-exhaust_56/big-honking-air-filter-r566/
  13. Is there a place nearby that can test the alternator before you buy another one?
  14. Is it worth it? I don't know. How many rear freeze plugs have you heard of blowing out due to heat in the rear cylinders. May be a problem with the lack of coolant pressure release during high RPMs along with some other underlying issue like weak freeze plugs.
  15. Can you bench press 50 pounds? Tool needed to get the carrier out and back in is a rear axle spreader https://www.vevor.com/differential-housing-spreader-c_10334/dana-spicer-differential-housing-case-spreader-dana-30-44-50-60-70-80-p_010780674643?adp=gmc&utm_source=google&utm_medium=cpc&utm_id=21040685019&utm_term=&gad_source=1&gclid=CjwKCAjw5v2wBhBrEiwAXDDoJW0ujeO9IT-MqMJpUAHGEaiOTnYXBl9kzBajCLoWtsREe5IpPrxQSxoCRycQAvD_BwE.
  16. I never had to R&R the whole axle assembly to change bearings. Jack the back of the truck up and put jack stands under the axle. Now remove the cover and drain the housing. Remove the driveshaft and the pinion nut; I always market the flange and pinion, so they go back together the same as they came off. Remove the rear tires and axle shafts. Install the spreader, remove the carrier bearing caps and remove the carrier; be sure to mark the carrier bearing caps so they go back the same as they came off. With a mallet and a block of wood beat the pinion out of the housing. The front bearing should come off and the rear bearing can be pressed off and the new one pressed on. Remove the old races out of the housing install new bearing races, pion and new front bearing. Inspect the carrier bearings while out of housing. If they are bad press them off keeping the shims to back on to the same side they came off and press on the new bearings. Put the carrier back in and torque everything to specs. I've replaced whole rear axle assemblies in Volvos and Chevy Astro vans jacked up off the ground with a floor jack and another person to help man handle the unit. It's not hard to do.
  17. I've done a few pinion bearings in Dana rear axles and they aren't that bad. You'll need a spreader to get the carrier out and back in, a big hammer to knock the pinion out of the front bearing/housing, a press to remove and install the rear pinion , and a big torque wrench. There will be a shim under the rear bearing, just reuse it when the new bearing is pressed on to the pinion.
  18. I've fixed leaking PS reservoirs that crack where the mounting bolts go through the sheet metal by using a brazing rod and acetylene torch; don't use JB Weld, it won't hold up to the vibrations.
  19. The 12 volts comes from the transmission relay and is used to power the torque convertor solenoid, overdrive solenoid and the variable force solenoid (governor pressure solenoid). With the 8pin transmission connector unplugged The PCM would not get a transmission temperature signal or a governor pressure signal.
  20. Don't have one. I use Valvoline 75w-140 full synthetic gear oil, changed out every 45k miles.
  21. I removed the lockup switch when the Pac Brake was installed but, for your purpose, I don't see why it wouldn't work. Here is the wiring diagram for what I did but it can be modified with the ground wire going through a switch then the resister to ground. You could run it through a relay with a switch like the relay on the right side of the diagram. The relay on the left side is for release of the lockup with the foot brake option.
  22. I going by what my friend told me, a 360. Maybe I didn't hear him right or had a senior moment. I'll check with him tomorrow.
