derez
  1. thats great to hear i will keep you in mind and spread the word to friends.
  2. my 05 gets around the same milage. i just figured it was because of my mods.
  3. trucks looking good. i like the black rims better.
  4. welcome to the site. do you have any plans on running any specials on stuff on here?
  5. try getting yourself some diolectric grease and put on it. see what that does.
  6. derez replied to derez's topic in Introductions
    when do you go from being a limited member to a standard member
  7. derez replied to derez's topic in Introductions
    thanks im sure i will have questions.
  8. i work at an rv dealer as a tech and i would have to say the pull rites would be my choice. i havent seen any problems with them siding or binding like i have with other sliders. the icing on the cake for them is that when you pull them out of the bed of your truck there is no rails to deal with just a flat surface.
  9. derez posted a topic in Introductions
    just want to say hi to everyone and say that this site is very well done and alot of useful information. im also a member over at cf.
  10. heat shrink butt connectors is the way i go. i feel the butt connectors work alot better and then you throw in the heat shrink part of them and you cant go wrong.
  11. i dont think there is anyway of tell if it was fixed without taking off the timing cover. its a easy fix if its not already done.
  12. im hearing alot of good stuff about this. i just cant wait for them to have it available for the 05s.
  13. thanks for the info. ill keep this in mind.
  14. i was wondering because they make a tool to shut it up, for when you have to have the door open to work on it.
