Cumminsguy5.9
  1. The code that I found is linked in a file in my update post. Anyways the code is U010C which states usually low voltage, short in the + or - on the can bus, or in rare cases the module itself is shot. I should also add that I wouldn't think the vanes are sticking due to a build up as the truck is deleted with a 5" pipe, unless I'm wrong. The truck has been deleted most of its' life I think there is about 88k on the dash now.
  2. If anyone knows how to upload the diagnostic file with all of the PID's from the launch controller I'd be happy to do so if it helps anyone out. I have two files about ~10 minutes in length of graphs and percentages for all the items in the truck. I understand that this is most likely a(n) electrical issue. I'm just confused as to why it won't work for a few minutes every time the truck is started and then it starts working again. I'd assume that if it was electrical or something in the CAN bus it would affect other items as well and wouldn't just start working.
  3. I wanted to start this thread so that I could finish it when I get home from work. I am having some issues with my 2013 ram 2500 and need some insight. A couple of months ago I noticed that on a cold start the truck would blow grey smoke and my exhaust brake would work periodically. I wrote it off as a stuck injector and put some diesel treat in and the grey smoke went away. Every so often the exhaust brake would act up but it wasn't anything major nor did it throw any codes. Just recently maybe 4 weeks ago I got a code. I don't remember the exact code but I do remember some of the problems it said it could be. Low battery voltage, bad wiring in the CAM/CAN BUS, and something else I can't remember at this time. When I start the truck with the code there the brake will not work for a few miles and then its perfectly fine braking and building boost. I would assume that if it was indeed a wiring issue the issue would persist throughout the drive not rectify itself a few miles into it. Which leads me to a battery issue, all the connections are clean and tight and the batteries have good voltage. New of last year this time. The alternator is also charging well. I have another issue unrelated to the turbo, not sure if I should start a new thread or leave it in here. The truck is a manual with a south bend dual disk clutch. When I serviced the truck I overfilled by a quart and am running the royal purple synchromesh which was recommended to me on another forum. And when I tell you this is a very sporadic issue I mean very. I cannot replicate this issue reliably. On 3 separate occasions when in reverse something binds. The first time it happened it felt like I hit something, it stopped the truck that suddenly. Checked around and didn't hit anything, tried backing up again and same thing so I pulled front a bit and backed up again perfectly fine. There are no issues driving normally just backing up every now and then. I don't feel any abnormal amounts of play in anything or see anything blatantly wrong. This one to me is tough because of how rare it happens and there could be so many possibilities. I have graphs of driving the truck normally on my scanner, they show the turbo actuator and all the values i'd think anyone would need/want to see. I will upload them when I get home. The files will also give the code number as well.
  4. Hey Guys. I’m debating on what I want to do here I have a 2013 2500 outdoorsman that I want to put some better seats in. I saw on some other sites that they used the corbeaus lg1 and they said they fit but I would like to keep my power seat on the driver side if possible. My other option would be to do an air ride seat but I haven’t really found much information on if they would even fit with how tall they would be. Im open to any recommendations as well if anyone else has tried doing something like this or found better seats anywhere else.
  5. It had 65k I’ll do them sooner than later. Do you have any recommendations?
  6. Regrettably I have gotten ride of the ole’ second gen and finally went out and bought myself a 4th gen. IMG_2525.MP4
  7. Very interesting.... I will have to look into doing this, they have had more than enough time and chances to get this taken care of.
  8. I was never much a fan of the air dog systems. A couple of my buddies had the same issues with the same pump. They both in turn trashed their vp's. Yeah that is a cigar box
  9. Not too sure of the year it was on the truck when I bought it but it’s the block replacement one. These are the photos of the destruction of that bearing. It sounds like you have the whole system with the dual filters, if I’m not mistaken those were fine. I think the one I had was the second generation.
  10. Alright, for anyone still following this thread heres an update. Took the truck to a local shop and had them do all the work i needed ( started a job working third shift makes it hard to work on things when its decent out) They threw on a new pump and sent me on my way. paid an arm and a leg ( i had them take care of some other issues as well). so thats the good side of things. its now close to the end of feburary and xdp still has yet to get me a refund on my bad pump i bought through them. they now have the pump i bought and my old pump. highly irritating knowing i have a $1500 set of pumps waiting to be tested and an answer. now they are saying that they dont have warranty paperwork from me or the shop both the shop and i have email proof that warranty paperwork was sent in. DO NOT I REPEAT DO NOT BUY FROM XTREME DIESEL PERFORMANCE they will screw you any way possible it seems
  11. Just a heads up depending on which gen of the raptor pump you have they only have a single sealed bearing. In short the seal on mine went and caused me a lot of headaches because diesel was able to leak into the motor windings and trashed it. I have since upgraded to the fass titanium signature series 125 gph with the extended filters. I was able to get rid of the stock filter but do make sure you replace the bolts if you choose to go this route you’ll blow your intake gasket. I push 19-20 psi all day with no problems.
  12. I don’t consider any thing as non productive. You ask me something that I should have put in my original post. I do appreciate all the help you guys have given me on this. As far as xdp goes when I approached them about the pump as far as who rebuilt it and where it was tested was inconclusive they didn’t want to give me an answer. I’m just going to send it back for warranty, wait for my money back and buy another from somewhere else. Do you guys have any reputable sources I tried looking for the list @moparman1973 had posted awhile ago but I can’t seem to find it.
  13. Pretty sure about the wiring John I do appreciate the advice though. The wiring is good I cleaned the terminals and put some dielectric grease just to be sure.
  14. Is the p0252 another vp death code? I haven’t been able to find out much info on it. They all say the same thing fuel metering control valve. Yeah I did pay with a cc I’m just kinda upset that they want to play games like the pump wasn’t even a week old and xdp is blaming a “REMAN” injection failure on me. I understand I don’t know much about these trucks but I’ll be dammed if I get ripped off.
  15. What’s going on guys? So as per my last topic the vp44 was my issue for whatever reason my edge wasn’t allowing my ecu to throw any dtc after figuring that out I found the p1628 or whatever the vp death code is can’t remember off the top of my head. Alright, replaced the pump with a reman vp44 from xdp and new fuel filters. Got the truck primed and she took off. Ran for about a day or so and then boom no fuel to the injectors again. Even though I do not like doing it I tried anyways I gave it a breath of ether and cracked the injector lines and still no fuel. Okay fine play hard. Towed the truck home and figured I’d call xdp and ask for my warranty (mind you this pump is only 2 days running on this truck give or take a half day and no I left my wire tap off for this very reason just incase). Anyways talked to xdp and gave them my new code it was throwing which is p0252 fuel metering control valve if I’m not mistaken. (Bad pump?) No to them that means dirt in the pump so I pulled my line into the pump and ran it for I don’t know 10-15 seconds into a 5 gallon bucket and found no dirt. Pulled filters and there was some dirt not much to make me worry though . Maybe I am mistaken but to me that means that 1 filters are working and 2 there probably isn’t dirt in the pump it’s self. Xdp wants to play games and I’m pretty irritated I want to make sure that I’m not in the wrong here guys. P.s. they want me to send the pump out pay shipping to send it to a testing shop and they are two weeks out and if I need a new pump xdp is also two weeks out. -kindest regards Eric
