Hi all,
I will be dropping the pan on the my 47re tonight to install the Mag-Hytec pan and isspro sending unit,
I have not found much info on proper replacement fluid.
I am looking to use the valveoline ATF+4,
any issues with that pick?
Thanks
BTW no idea what i am going to find but i have no issues with the trans so i am not expecting to see much
Brew
  • Replies 22
  • Views 3.3k
1. install sender unit into T fitting.
2. cut pipe. I used a small tube cutter.
3. take the pipe off the heat exchanger and cut off about 3/8" from it. use a hack saw for that.
4. slide compression fittings on both pipes.
5. install T fitting with sender unit on to the pipes and hand tighten the fittings.
6. reinstall pipe on to heat exchanger.
7. orientate the sender unit.
8. be sure the pipes are pushed in to the T fitting, then tighten the compression fittings.
I bought the return trans line that has the port for the temp sender. Got the line from Genos IIRC
