Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
Alright, need some help here before I take a sledgehammer to it. A few months ago I had to replace my power steering pump. I figured since I was going to pull the vacuum pump anyway, I might as well be on the safe side and clean, inspect, and replace the o-rings even though it wasn't leaking. I've now put three sets of o-rings on this pump and I'll be @#$%ed if it isn't leaking again. I make my living as a mechanic but I may need to think about a career change. The first two sets of o-rings were from Gould. A buddy had bought it but ended up selling the truck so he gave it me. I followed the instructions exactly and torqued everything to spec. First time, leaked between the retainer and housing. Second time, same scenario, but leaked from seal lip. This time, I'm not sure. I flipped it the bird, did a lot of cussing, and came in to ask you guys. Each time I have cleaned everything like I was doing surgery. There are no burrs, no wear marks, no dirt, nothing. Only difference I saw between seal kits is that the Gould kit seal fit tighter in the retainer compared to the Cummins. Any help greatly appreciated!
