- Replies 56
- Views 15.6k
organicfarmer 21 posts
AH64ID 12 posts
Wild and Free 9 posts
dorkweed 5 posts
Yep, but those are useless numbers as the A/R ratio is the magic tuning number and knowing your fueling your power needs and usage to determine where the ideal power range and spooling points need to
On the note of Drive pressure, I was "tuning" my exhaust brake. I turned it on, and revved it up slowly until I hit ~60 psi, it was about 1800 RPM. I looked at the tail pipe and it was hazing pretty
Were I looking for more turbo; I'd look real serious into a set of "towing twins". You get the quick response of the smaller turbo, followed by the mega-boost once the bigger one once it lights. Do
I am chewing the treads for info on turbos.... my cr has a healthy he351cw holset that i have on my list to modify or replace.
why change? i have a j-06 Smarty thats begging to be allowed to be set on sw3 [100hp]
the exhaust housing is tight [9cm] [internal rgr]
turbo threads that end in ''gray hair'' are to common! i want to do it once!
my goals= 100+hp tune....maybe 50hp inj. if/when i change inj. cai exh. fass lift pump more????exh. manifold? cam????
you get the idea
mostly empty driving low elevation some hills some towing
Edited by organicfarmer
