Anybody know how to reset an air bag warning light on a 02 kia sadona? Doesn't show any codes, no cel . I've disconnected the battery for 20 min hoping it would reset, but didn't do it. Any suggestions? It's my wifes car with only 50k ,bought new never been in accident.
  • Replies 10
AirBag system has a problem. The computer will only reset the issue after the repair has been made. It might just be a bad connection. Go over all the airbag wiring and double check all connections.
Danger Icon DANGER!
Make sure to do this while the battery is disconnected. Also make sure to disconnect the battery and leave alone for at least 10-15 minutes before starting work. I would hate to see you get injured by deploying a airbag by accident.
Danger Icon DANGER!
Thanks Mike. I'll try to figure it out ,but I've pretty well checked all the connections. I'll probably have to go to the Kia dealer. I suspect a bad air bag modual, but I have no way to trouble shoot it. Thanks again.
     Art
When you disconnect the battery you can touch the two cables together. This will drain the capacitors right away with no worries of 'did I wait long enough'. There is no way to know what the problem is unless you see an open circuit in an SRS system or use a code reader to find it, fix it, and clear the code.  I have found that the code will only clear with my code reader.
thanks for your help.Do you need a SRS code reader or will my san11 gauge work? It doesn't show any codes on it?
You need one that can read and clear SRS codes. The scan tool I use for that is a Launch Creader CPR129 There are other scan tools out there that are less expensive. The CPR123 will do the same thing for about $200 less. The only authorized sellers for Launch USA are: Mac Tool, Matco Tool, Cornwell Tool, and NAPA http://www.launchtechusa.com/assets/launch_retailer/dealers.html. There are a lot of cheap Chines knock offs on E-Bay and Amazon. They won't do all the functions and you can't up load new software to them.
Thanks for the information. I called a shop that my family has been using for 40 years and decided to let them figure it out. They have a SRS scan gauge .Some times  I    have to bite the bullet and realize I can't fix every thing.Thanks
Air bag warning light was reset, they had a couple of codes but once they were cleared they didn't come back .Cost me 78 bucks a lot   cheaper than buying aSRS scanner
The codes were B1112 (ignition voltage low) and B1511(driver side buckle switch open or short to ground)
   Thanks for your help.
I don't post much, but I sure get a lot of info from all you guys.  I really appreciate this web site and all of the members. I kinda feel like I know Them.
Thanks again
Art
  • Current Donation Goals
    • Raised $20
