radio lost power i need some help
- Replies 7
- Views 3.1k
Mike Daley 3 posts
Mopar1973Man 1 post
Buzzinhalfdozen 1 post
Me78569 1 post
so first off i want to say that i am new to the forums. iv'e searched the web for someone who has had the same issue but so far i cant find it!
so i went to my camp and all was well. the next day i unloaded all the dirt bikes and quads off of my flat bed and trailer and all was well. then about 30 min later i jumped back in the truck to run to the corner store and the radio didn't work.. weird.. it never came back on either.
so when i got home the first thing i did was break out the multi meter. the battery power wire in the radio harness (yellow) was only coming up with .25 volts. and the ignition power wire (red) was only showing .20 volts. i checked the fuse on the drivers side of the dash in that small fuse panel and it was fine. so i stuck the multi meter in there and it was only showing .25 volts as well. i pulled every fuse on that panel and could not find a blown fuse. i also went under the hood into that larger fuse/relay panel and couldn't seem to find one for the radio.
my interior lights as well as everything else works fine, just not the radio. does anyone have any ideas? please help me!
