- Replies 10
- Views 2.3k
dripley 5 posts
dave110 2 posts
klcammie 1 post
joecool911 1 post
Hi all! It's soon ball joint time for me. In my research some say you need a $300+ tool set to do them. If that's the case I might as well pay a shop to do it but I like to do my own work. I've never done these but I did on my F2504x4 and I remember the loaner tool from Advance didn't have big enough parts to handle a larger joint like that. I have access to an arbor press and can make cups and stuff in the machine shop. Do I really need a ball joint press? Can't I just take the nuts off and hammer the joint loose from the axle and then take the whole knuckle and put it in an arbor press? Is there a write-up anywhere on this or for those familiar can you give me a step by step or any tips like which to take out and put in first? Top or bottom. That way I won't spend so much time in trail and error. I'm not worried about getting the unit bearing and axle out, been there too many times, just the ball joint part. Thanks!
