Truck died on highway, and will not start, no other electrical problems?
2007 Dodge 2500 RAM 5.9L  4x4 Mega Cab (82,000 miles well taken care of vehicle): Engine died at highway speed, and will not start with no immediate electrical problems.  I was traveling on a 700 mile trip for labor day holidays, and after five hours during the returning home leg and while on cruise control at night, then without any notice the engine just stopped running/producing power at 60 mph and truck coasted to a stop.  There was no engine life but would crank and did not start or even show any signs of firing.  Immediate checks of fuses determined that there were no blown fuses.  Just to be sure I replaced fuse #41 for EGM but this did not help.  Luckily, I was 7 miles from home and got towed by a friend to house - whew!.  This morning, I checked engine codes and retrieved a P2509, ECM/PCM intermittent power and an intake low voltage code which, I cleared and these did not return upon several crankings of the engine.  No other electrical issues or instrument indications provide any further symptom identification.   I also unscrewed and checked the fuel filter housing to check for fuel and it was full as well as I can hear the fuel pump runing during the the ignition switch being first turned on.  I will empty it next and watch it refill to verify fuel is being pumped from the tank too.  So my initial thoughts are that for such a sudden (without symptoms or warnings) engine to cease running there must be an electrical issue of some sort.  I don't believe the ECM is without power or ground (initial assumption), since all wiring looks good and the batteries are both in good standing, but I plan to pull PCM connector and follow continuity checks per P2509 troubleshooting steps.  This truck has no maintenance history problems, with the exception when I washed engine compartment and got fuel rail pressure sensor connection wet and it went bad causing loss of power and surging symptoms.  With this experience and all the research during that trouble shooting effort, I initially thought the FCA was going bad and purchased one to have on hand before I narrowed down the problem to the fuel rail pressure sensor via consistent associated engine fault codes.  So, I am already at a loss for where to go if the PCM continuity checks are ok, which I fully believe will not be an issue???  Is it reasonable to believe a faulted FCA could cause shutdown of the engine suddenly?   ...or could the fuel pump itself fail suddenly like this also??? Any other trouble shooting leads will be welcome.  Thanks.
  • Replies 36
  • Views 15.6k
  • Well I am a VP man and cant add anything to ya'lls discussion much less trouble shooting. I do like that you want to see it to the end and share what you found out. I have seen to many threads that ge
  • I did a cut and paste (see below) from gmctd that was placed on the Dodge Diesel Cummins Forum (thanks for sharing), which I can not  thank him enough as it is an EXCELLENT description/technical discu
  • +1 I came accross a lot of those incomplete posts as well while researching this topic when having similar fuel issues (extremely frustrating when u have a broken down truck). This is a great contribu
My opinion isn't worth much....but I would start out simple before delving into wiring and PCM/ECMs.  Verify that you have fuel flowing, I know you said that you can hear the lift pump, but that may not mean that you are getting fuel.  How did your fuel filter look?
+1 on checking fuel, you can also disconnect fuel pressure at the CP3 pump by removing the line that goes to your cp3 from fuel filter then placing it into an empty container (I use a empty water gallon) bump the ignition 2 times and check if any fuel is in the gallon if not bump 2 more times if still nothing then fuel is the culprit.
If you decide to give this a try you may want to have some crush/copper washers handy for the banjo bolt on cp3.
Thanks for the input!! I was thinking the same; it being fuel.  So I have already checked the fuel flow to the filter by opening the drain and turning ignition on.  There was much, much more pressure/flow observed!  The fuel filter is very new less than a 1K miles due to changing it out when i was troubleshooting during that surging/no power condition (also included water in fuel light)  after washing engine compartment (when i was rinsing salt away from winter) a couple of months ago (which turned out to be the fuel rail pressure sensor going bad).  I will check the fuel flow/pressure to the CP as suggested too (thanks for reminder of crush copper washers, probably the same as on the brake caliper hoses?).  I have not ruled out the FCA, but purely a guess at this point.
However, ​I am leaning toward the batteries/altenator or insufficient power due to several factors.  What got me more interested is that I read a couple of posts about guys having crank/no start symptoms with a bad alternator (high ripple) and bad battery (faulty neg connector on passenger side) along with my engine codes (P2509, ECM/PCM intermittent power and an intake low voltage code), i.e., the only solid indications to go on.  Something is coincidental here??  But another aspect to this is the fact that I have original OEM batteries and Alternator (2007 truck) that I was already going to proactively replace as preventative maintenance this year since I have girls who tow horses, and the reliability of the truck is paramount to me for this reason.  But more importantly, after cranking on the engine to try and get the codes to repeat themselves i.e., after I cleared them out, the batteries ran down very quickly with maybe 3 or 4 attempts.  I also noticed the voltage indicator gauge was very slow in responding to indicating battery voltage when turning on the ignition, even before depleting the batteries from the cranking.  These batteries have already endured 6 Chicago winters, some of which were -10 and -15 degree week stretches where the batteries were stressed several times over these weeks.    After cleaning them up, topping off with DI water and recharging lots of gassing was observed yesterday - more than normal in my opinion.   Regardless, I went on and got two new Sears duralast gold 65's (ordered online, waiting on order pickup notification) and mail ordered a "new" Bosch alternator as well.  This is mainly due to it being time to replace these for reliability insurance with my girls towing horses concerns, much less being near/at end of their service life and with them being suspect for potentially causing voltage/current concerns with the PVM/ECM.   I am holding off on going thru the P2509 code procedure to check the PCM/ECM connectors as is the falt code response steps as you suggest for now.
Hope I am on track for resolving.  It would be nice to have more indications.  I still can't get over how it stopped runing all of a sudden, not to run again.  No loud noises, no electrical fluctuations, no idiot light, nothing?.  I must say, this is a "diesel" experience!  Thanks, I will keep posting for others into the future and if you think of anything else please share.
I have had two different experiences where my gen 3 truck stopped while driving on the fwy.  One fix was the replacement of the lift pump and the other was the replacement of the cam position sensor.
I called the first one (I could see it on my guages) and the second one took a diesel shop to identify.
John, thank you very much for these symptom/resolution inputs that you have experienced!.  I believe the lift pump is being ruled out with the observed flow/pressure it is providing to the filter housing, but I will do some more mechanical checks downstream for pressures and flows up to the injectors. Interesting enough, you being a pilot can appreciate that when my failure occurred I was driving (at night) and performing routine panel scans, which upon engine stop producing power/running there were no instrument/panel indications of any sort, nor any other symptoms that I could identify or associate when the failure occurred (very perplexing).  The cam position sensor however is officially being added to my list!  I am continuing on staying my systematic course for now with batteries/alternator replacement.   In the mean time if the cam position sensor is cheap/easy enough it never hurts to easter egg something cheap and easy.  Btw, were any codes captured that you can recall by either of your two events?
I have had FCA issues in the past and throughout the 2yr time period of random symptoms and diagnosing it never reached a “No start or Full Shut Down” type of failure. While I was in search for a solution for that issue I did find that the COV (Cascade Overflow Valve) can cause no start situations and can even cause engine to sporadically shut down. Unfortunately this is yet another fuel system component that does not have a proper way to detect failure through DTC but it is one of the least expensive parts to replace if you want to give it a shot.
Ok,  All (including Edwin ...and btw thank you for your reply which makes sense to me!),
After spending most of Sunday afternoon replacing the batteries, painstakingly cleaning/replacing all leads and terminal connections, lifting grounds and doing the same, carefully inspecting cables/wires and wire tying them neatly (to aircraft standards), then after performing continuity and voltage checks for electrical connections, I put system on charge, and instead of trying to crank engine, decided best to drink a beer and pondering how to go forward if the battery, ground, voltage to ECM is not the problem.  i needed to relax and rethink everything so far with all you inputs, internet troubleshooting data, and getting rest for work week ahead.
This evening after returning from office, I checked the charging of new batteries and system voltage as indicated on instrument panel (reading obtained was 13.8-9 volts give or take +/-.1 vdc), then tried to crank engine with a resulting no start.  Being that the electrical system is now off the list and not being dressed for dirty work, I decided best effort would be (before I read Edwin's post) to disconnect the fca and try to re-crank.  Well, it started right up with a touch of starter!??  I had read in somebody's diesel post that a way to check the afca, was to unplug it, and try to crank engine, and if it started up then shutout down and replace.  I did so and also observed heavy white smoke from exhaust .  Now I happen to have an fca part on the shelf from my earlier troubleshooting efforts of the surging/no power condition associated with the failure of the fuel rail pressure sensor.  I will change it, and confirm its the root cause of the sudden engine shutdown with no warning/indications/other symptoms (other than crank/no start) during the labor day return trip home highway driving the shutdown was experienced.   This being where the troubleshooting sits to-date (i.e., appears to be good news for failure mechanism), I will comment further that there was no definitive fca failure cause of condition associated with a sudden engine shutdown/stop running failure that anyone has posted nor Mopar documented where this check was warranted as a potential problem for the condition?
I still plan to replace alternator when it arrives, and upon verification this is in fact my problem, it gives rise to whether I should stock critical parts (like pressure sensor, fca, fuel filter, etc) in the truck?  These part failures are so easy to replace in the field that had I been towed to a mechanic, I am sure the cost of these parts would pale as cheap compared to these bills, and time or part costs to boot!
Edwin, I agree with your situation with the fca operation you encountered because I had been under the same impression of its faulty operation.  I had initially bought the fca when troubleshooting my surging/no power condition caused by the failure of the fuel rail press sensor following washing the engine compartment this past early summer.  I did have the pressure relief valve (cascade overflow valve?) on my list and had it not been for this turn of events would have further pursued the fuel system downstream of the lift/tank pump.  I have carefully documented yours and others input, which will go into my manual for the truck because it is only time until it will be needed!!!!  Thanks
Replaced the FCA tonight and interesting enough truck now starts, then shuts-down within 15 - 20 seconds. the start reaches between 600 - 700 rpm then slowly dies/stops running.  It now throws the code P0088 (i.e., Fuel Rail/System Pressure - Too High code) consistently (after clearing codes several times).  Not sure what to make of this so I must study some more and determine where to go with troubleshooting.  One peculure aspect is that it only starts from the first key on position and it will not start when turning it from the second key position (ignition lights on) - not sure what is the reason for this either?  Initial thoughts now are to follow-through with fuel system checks down stream of filter housing unless I learn more about the P0088 code.  The COV and Cam Position sensor haven't been forgotten.  Any additional thoughts are welcome.
My guess is that the fuel system has less time to pressurize and flood the engine in comparison to if you are sitting in the second ingnition position (ACC position?) allowing more time for fuel to circulate the system which is what i beleive the COV is there to prevent. <<-- thats just a wild guess ...lol... so please don't quote me ... unless it works :wink:
Gudge
I have been following your post and you seem to be going about everything the same way I would approach if it were my truck. The FCA symptoms seem to have you at least headed in the right direction, as it being a fuel related issue.. I wish I could offer more input but I have never experienced what your seeing other than a lift pump failure which was relatively easy to diagnosis. Please stay with this post as you eventually get to the bottom of this. I think everyone could learn something from what you are dealing with. Third gen trucks seem to be very reliable, but nothing is bullet proofq
Current Analysis:
Excellent input Edwin, I really appreciate the thought here with the delta time to pressurize logic.  Btw, the ignition switch 1st position more correctly as you state is the accessories (ACC) position, and the second position is Run, and the next position is Start.  I was not sure since they are not labeled and my thoughts were too far ahead with my focus on adding all this troublshooting activity up.  I also may have overstated how long it runs after starting because it is more in order of 5 seconds, tops.  However, the engine sounds very normal after starting - just about stabilizing at an idle condition, and then as one would think everything is good, it slowly dies to off with no discernable parting good-bye.  The starting, running, and shutdown as I explain it are "exactly" consistent in behavior each and every time.  Not knowing yet (unverified) if there is actual high pressure condition (which I do believe is occurring "now" as was not "before" with the old FCA installed), your thought sounds logical from what I understand about the fuel system (quick course I found and viewed on the Cummings U-Tube videos about the 2003 5.9L diesel design/operation - very informative for us novice diesel owner/mechanics).  I can't quite grasp why it starts however with this new FCA and not the old FCA (btw i shook the old FCA as I sit here and write this blog, and I do hear a very light rattle sound, but can't remember about the new one ...if this means anything?).  My initial thoughts are that the old FCA may "not" be bad (i.e., I did not check whether the truck will start from the ignition switch 1st position (ACC) or not when the old FCA was installed?).  My conclusion about why I thought that the origninal FCA was potentially bad was due to when I disconnected it electrically and the truck started right up - but had very noticeable white smoky exhaust and I  immediately shut the truck off as to not run it with no ECM signal to the FCA, believing it to be the smoking gun.   I sort of learned about this ignition switch start characteristic as I was thoroughly testing/cycling the new FCA and batteries ( when i got the no start response) and also, since when changing out the FCA I heard a venting noise, which caused me concern that air was going into the system since I did not see any substanative leakage of fuel from the CP3 and I wanted to rule out air in the fuel flow to the injectors.  I did cycle the ignition switch several long times to vent the system before trying the first crank to start.  Being the theory is a wag, it will stay as a hypothesis for now.
Angus, I will continue to post my troubleshooting efforts until the root cause is found and differentiated from the necessary learning or trial by error steps being taken, and documented for all others to use.  I too am frustrated more from the "large majority" if not closer to "all" the other posts I have read very rarely come to conclusion/closure for their cause or ultimate fix!!!  Not to say there aren't a "few" (mainly the ones that find the fix step one, not the ones who spend multiple troubleshooting steps with highly engaged troubleshooting thoughts), for those others that are reading and not to be offended.  Operating experience should be shared to save and benefit others regardless of the pain it produces for us lucky ones.  It is not much help if conclusions reached are not shared.  Anyhow, two cents worth and my plan is to put my money where my mouth is so I can criticize and not be guilty.  No actually, knowing how painful troubleshooting can be, "all" those others at least get credit for starting their communications but by the time they finally arrived at their conclusions, they more than deserved an end to their misery and to take it to the grave.
Revised Troubleshooting Plan:
Ok, the new theory (offered above) and the associated suspect cause: failed COV (which at this point I am not fully versed on this component/function yet - must do some research and develop my plan to test it).  However first, since there is unfinished business ruling out or understanding the FCA more thoroughly, I should remove the new FCA, re-install the old FCA, and determine whether I can get the same engine start condition from ignition switch 1st position (ACC).  I will also conduct the so called rattle test and take continuity readings on the electrical side on the new FCA ( which btw the old FCA terminal readings were approximately 2.4 - 3.0 ohms and no grounds) in order to have the data if nothing else.  This will hopefully rule out or confirm the FCA failure.  Then if it is failed low (i.e, no fuel being demanded from the CP3), this would indicate there is another issue in the fuel system (i.e., two failures), in order to be consistent with the new FCA (considering it is good) over pressurizing the rail.  If it is not failed, then if both FCAs are good there should be consistent start characteristics (i.e., starting, and continuity checks),  There is one condition that may be a cause however, that both FCAs are failed high, but this should be highly unlikely ( and may end up only being ruled out by finding what is causing the overpressure condition).  I have to think more about and factor in why no overpressure code (P0088) was received the night of the sudden engine shutdown but yet now with the new FCA and/or with this ignition switch start characteristic it is consistently is setting the code?  From what I can determine with internet fourm research/reading and the help of this site: the suspect cause areas are: COV (CP3 internal pressure regulator) or a fuel return line that is not routing excessive fuel back to the gas tank (there are several of which I must determine which ones will cause a rail over pressure condition) if the FCA is operating correctly.  I will hold off with further checks of the fuel system until this FCA plan leg is completed, data obtained, and more analysis conducted.  More to come.  Thanks, and all input is welcome, much less needed!
http://www.genosgarage.com/product/f-00n-200-798/fuel-system-accessories-replacement-parts
This appears to be about the cheapest part a person can replace in the CR fuel system.. I`m a little baffeled that there is not much information out there as to its function, and symtoms of a COV failure?  Perhaps the failure rate of this componet is so low it has not warranted much discussion??
Well I am a VP man and cant add anything to ya'lls discussion much less trouble shooting. I do like that you want to see it to the end and share what you found out. I have seen to many threads that get 90% there and they just disappear. i look forward to seeing the conclusion to this and wish you all the luck.
I did a cut and paste (see below) from gmctd that was placed on the Dodge Diesel Cummins Forum (thanks for sharing), which I can not  thank him enough as it is an EXCELLENT description/technical discussion of the 3rd Generation Fuel System Operation!!!!  I am sure it came from Cummins.  This was too good not to share and include for all of us that just got to know what is going on so we can make logical decision with our troubleshooting.  Now with the accuracy of this technical documentation, it should speed things up with anybody's future troubleshooting!
I took some time to get my thoughts together along with factoring together this technical information and all others inputs, and subsequently created a couple of diagrams and notes for  tools.  I drew-up a flow diagram of the fuel system discussion that is focused on troubleshooting use, which I will neat'n up and post for ease of troubleshooting the fuel system for others.  It is a quick way to take in the entire technical document without spending a lot of  time reading and understanding it.   The major components that should be checked, along with relationship between electrical and mechanical, as well as where the ECM fits into the picture is easy to see, allowing one to follow the fuel system and make determinations on what may not be working properly.  It puts to rest hear-say, and sketchy memories too.   This should aide others (myself included) in troubleshooting their fuel issues much quicker than how long it has taken me already.  I also took time today to sketch a block diagram of my troubleshooting so far: i.e., condition, problem statement, symptom(s)/action(s), feedback loop, and focus areas.  This has helped me re-step thru what has happened, factor in new information, and organize my thoughts allowing me to determine "logically" next steps.  It may end up being something helpful to others too?  Then finally, I wrote my what/if thoughts for questioning why things happen the way they do/did, and what I need to do for answers, validation, or support/refute to develop additional actions or identify faulty components.  I know this sounds like a lot of paper thinking but after reading all the other posts that I could get my hands on, it helps sort thru complexities and entanglement for us folks going thru others experiences and data, then combining with our data and making logic of it all JUST IN ORDER TO identify the faulty component (end goal).  This saves money on not purchasing unnecessary parts or labor.
So if your wondering where this leave me now ...well, I believe in the last post made - I (you) can now determine it is fairly close to where I need to go for the failure/fix.  I still don't believe the FCA is failed, because as Ed 5.9 has offered, and now confirmed with the below technical information.  Because the COV provides fuel flow/pressure  from the LP side of CP3 pump to: 1.) the FCA that controls the "flow" to the HP side of CP3 pump then on to the rail, 2.) the lubrication flow at low pressure (43 psi), and 3.) the "press/flow" excess (i.e., regulated overflow) back to the fuel tank AND based on my current symptoms (Crank/start/shutdown from ign sw position 1/ACC - additional associated details about the start too, and P0088 code), it can be explained that because the FCA on startup (ECM has (allows) FCA demand "full" flow for startup mode i.e., up to full pressure on the rail (23,206 psi))  is not able to control rail pressure fast enough if the COV valve is not working properly to direct fuel flow down path #3.  The FCA eventually is able to respond from the overpressure condition by completely shutting fuel off from the HP side of the pump (as designed/expected operation).  If the COV is not relieving press/flow back to the fuel tank there is a pressure run away condition (or significant delay in reducing flow from the HP side of the CP3), hence P0088, high rail pressure condition followed by the FCA shutting off fuel to engine causing shutdown.  This makes logical sense, especially when you trace it on my flow diagrahm.  Additionally, this may not be the only failure component/mode that could cause high pressure on the rail, but right now it (COV) is the next logical and fuel flow path component (i.e., in sequence from the fuel tank in suspect) to troubleshoot and verify its proper operation/condition (thanks Ed 5.9L).  This will be done by finding a way to observe fuel flowing back to the fuel tank from the COV outlet.
However, as I stated before, there are some "re-do" actions to be taken.  I want to verify the hypothesis by looking again at the old FCA and verifying it is not bad, because this could change things some if it is failed.  It should act consistently the same as the new FCA and start the engine from the ign sw position 1 (ACC) if so.  After identifying another way to look at the FCAs and ECM, there are a couple more checks to perform: 1.) verify the ECM is sending a test pulse to the FCA with a test light across the connector contacts (this occurs when key is in ACC position), 2.) after removal of new FCA, measure continuity, ground, and visual observation of the static solenoid plunger position and compare it to the old FCA solenoid plunger position, and 3.) feel it operate during starting or with it in-hand while not bolted into CP3.   These checks need to be done so I can conclude that the FCAs and ECM are operating properly.
Now with plan in hand, time to go implement.  Will post results and include the diagrams and notes, if there is a way to post them?  Hope this will help others.
The following (below) is a cut and paste from gmctd that was placed on the Dodge Diesel Cummins Forum (thanks for sharing), which I can not  thank him enough as it is an EXCELLENT description/technical discussion of the 3rd Generation Fuel System Operation!!!!  I am sure it came from Cummins.  This is information that you must keep in your 5.9L Diesel shop notes!
CP3 injection pump system
I've edited excerpts from the manual for clarity and scope - read it if you will, ignore it if you must.......................
FUEL SYSTEM
A Robert Bosch high-pressure fuel injection pump is used. The pump is attached to the back of the timing gear housing at the left /front side of the engine
0612dp_08_z+2001_to_2004_chevy_lb7_duram
DESCRIPTION
The fuel system on the 5.9L Common Rail Diesel Engine uses a rotary mechanical fuel injection pump and an Electronic Control Module (ECM) and is a drive-by-wire system, meaning there is no physical throttle cable.
The fuel delivery system consists of the:
- Accelerator pedal position-sensor module
- Air cleaner housing\element
- Fuel filter\water separator
- Fuel temperature sensor
- Fuel heater
- Fuel rail pressure relief valve
- Fuel rail pressure sensor
- Fuel injection pump
- Fuel injectors
- Fuel tank
- Fuel tank filler\vent tube assembly
- Fuel tank filler-tube cap
- Fuel tank module containing the electric lift pump, roll-over valve and a fuel gauge sending unit (fuel level sensor).
- Fuel tubing\lines\hoses
- High-pressure fuel injector lines
- Low-pressure fuel supply and return lines
- Low-pressure fuel return line
- Overflow valve
- Quantity control Fuel Control Actuator valve
- Quick-connect fittings
- Water sensor\drain module
FUEL INJECTION PUMP
The Cummins 5.9L CRD uses the Bosch CP3 injection pump, used also on the DMax 6.6L V8 CRD and the Jeep 2.8L CRD
DESCRIPTION
A radial, 3-piston pump, with a gearotor pump attached to the back, is used as the high-pressure pump for common-rail fuel pressure generation - in this system it is capable of pressures between 300-1600 bar (4351-23206 psi) .
A spring-loaded Cascade Overflow Valve regulates internal housing pressure
Regulated internal housing pressure is oem-specific
The pump shaft is driven by the timing belt at 1:1 ratio to the crankshaft.
Fuel pressure is generated independently of the injection process.
A Fuel Control Actuator solenoid valve regulates injection pressure
The pump is lubricated by the pumped Diesel fuel and is not responsible for fuel injection timing.
OPERATION
GEAROTOR PUMP
DESCRIPTION
The gearotor pump has two functions
- draws fuel from the fuel supply
- increases fuel pressure for regulation to housing pressure required for internal lubrication and supplying the high-pressure injection pump
OPERATION
This fuel system uses a gearotor supply-pump attached to the rear of the high-pressure pump. This medium-pressure fuel pump is driven by the end of the high-pressure pump shaft, and can generate 20" vacuum at the fuel inlet at high rpm.
The gearotor pump is supplied fuel from the lift pump in the fuel tank through the fuel manager\filter.
The outlet of the gearotor pump provides pressurized fuel to a branched circuit internal to the high-pressure pump flange, which supplies both the Fuel Control Actuator solenoid valve and the Cascade Overflow Valve\regulator. Because the gearotor pump increases fuel flow and pressure as engine rpm increases, the pressure and flow is regulated by the COV.
The COV and gearotor supply-pump are not serviced independently of the high-pressure pump.
CASCADE OVERFLOW VALVE
DESCRIPTION
The COV is located on the front cover of the high pressure pump.
The Cascade Overflow Valve has three functions:
- regulation of lubrication fuel to the internal moving parts of the high-pressure pump
- regulation of the fuel pressure being supplied to the Fuel Control Actuator solenoid valve
- return excess fuel to the fuel tank
This regulated internal pressure, known as housing pressure, is determined by engine displacement and power requirements - the 5.9L CRD requires 5-12.4 bar (80-180 psi)
For comparison, the 2.8L 4-cyl Jeep CRD requires 5bar maximum (73psi)
OPERATION
The COV has a spring-loaded center spool-piece that has a drilled channel with three passages: one for initial low-pressure lubrication, one for lubrication at housing-pressure , and one for overflow. The valve is operated in three stages based on the level of pressure at the inlet.
Stage 1
When the fuel pressure entering the tip of the COV is between 0 and 3 bar (43psi), pressure is too low to overcome regulator spring tension and fuel flows through the center channel, only . This passage always allows fuel flow through to the pump center-ring and lubricates the pump bearings and internal moving parts. This circuit also allows air to bleed during initial cranking and returns the air to the fuel tank.
The COV is in Stage 1 during cranking, only.
Stage 2
When the fuel entering the COV exceeds 5bar (73psi), but is less than 12.4bar (180psi), the spool-piece moves against spring tension aligning a second passage for lubrication purposes.
Stage 2 can be reached during cranking and initial start up.
Stage 3
When fuel pressure exceeds 12.4bar (180psi), the spool-piece aligns with the overflow passage. This stage relieves the pressure into an overflow circuit that sends the fuel back to the inlet side of the gearotor pump, thus limiting maximum fuel pressure to 12.4bar (180psi).
Lubrication fuel continues to flow through all channeled passages during this stage.
Excess fuel is sent back to the fuel tank through the fuel-return circuit
Stage 3 is reached at over-pressure
FUEL CONTROL ACTUATOR
DESCRIPTION
The Fuel Control Actuator solenoid valve is located on the back of the front cover of the high-pressure pump. The solenoid is pulse-width modulated by the ECM and meters the amount of fuel that flows into the high-pressure elements inside the high-pressure pump.
The solenoid is inactive up to 30 seconds after IGNition switch is initially keyed to ON position to allow maximum fuel pressure to the fuel rail during cranking and start up. ECM assumes FCA valve control when CPS signal and rail pressure are within acceptable limits
OPERATION
The Fuel Control Actuator solenoid valve is a pulse-width modulated valve that controls the amount of fuel sent or delayed to the high-pressure pump elements inside the high-pressure pump. The ECM determines the fuel pressure set point based on engine sensor and rail-pressure inputs. If the actual fuel-rail pressure is too low, the ECM commands the solenoid to allow more fuel to flow to the high-pressure pump. This minimizes the difference between the actual fuel-rail pressure reading and the set point. The ECM will also operate the solenoid to delay fuel, reducing flow-rate, if the fuel-rail pressure becomes too high.
The FCA valve is commanded open by the ECM to allow the high-pressure pump to build maximum pressure (1600bar, 23,206psi), or closed to reduce rail pressure.
Thus, rail fuel-pressure can be increased or decreased independent of engine speed
High Pressure Pumping Plungers
The FQS valve supplies three high pressure pumping chambers. The pumping chambers have one-way inlet valves that allow fuel to flow into the chambers. The valves then close as the fuel is compressed, causing the high pressure fuel to overcome a spring-loaded ball-and-seat outlet valve.
All three pumping chambers are tied together in one circuit internal to the pump and provide high pressure fuel between 300bar (4351psi) and 1600bar (23,206psi) through a steel line to the fuel rail.
The pump is driven at 1:1 engine speed and is not responsible for injection timing.
Pump function is to provide fuel at high-pressure, while the ECM controls injection pressure and timing.
FUEL RAIL
DESCRIPTION
The fuel rail is mounted to the cylinder-head cover\intake manifold. The rail distributes regulated high-pressure fuel equally to the fuel injectors.
A pressure sensor is screwed into the rail so ECM can read and regulate system pressure.
A pressure valve is screwed into the fuel rail to allow regulated overflow return to the fuel tank.
OPERATION
The fuel rail stores the fuel for the injectors at high pressure. At the same time, the pressure oscillations which are generated due to the high-pressure pump delivery and the injection of fuel are dampened by rail volume.
The fuel rail is common to all cylinders, hence it’s name "common rail". Even when large quantities of fuel are extracted, the fuel rail maintains a constant inner pressure. This ensures that injection pressure remains constant from the instant the injector opens to the end of the injection event.
PRESSURE LIMITING VALVE
DESCRIPTION
The fuel pressure limiting valve is located on the top of the fuel rail.
OPERATION
Fuel pressure at the fuel rail is monitored by the fuel rail pressure sensor. If fuel pressure becomes excessive, the high pressure fuel overcomes a spring-loaded plunger with tapered-seat outlet valve, causing the pressure limiting valve to open and vent excess pressure into the fuel drain circuit, and back to the fuel tank.
FUEL LINES
DESCRIPTION
LOW-PRESSURE FUEL LINES
All fuel lines up to the fuel injection pump are considered low-pressure. This includes the fuel lines from the fuel tank module to the inlet of the high-pressure fuel injection pump. The fuel-return lines and the fuel-drain lines are also considered low-pressure lines.
High-pressure lines are used between the fuel injection pump and the fuel injectors
HIGH PRESSURE FUEL LINES
High-pressure fuel lines are used between the high pressure fuel injection pump and the fuel rail, and between the fuel rail and fuel injectors
All other fuel lines are considered low-pressure lines.
OPERATION - HIGH PRESSURE FUEL LINES
High-pressure fuel lines deliver fuel under extremely high pressure - between 300-1600 bar (4351-23206 psi) - from the high-pressure pump to the rail to the fuel injectors. The lines expand and contract from the high-pressure fuel pulses generated during the injection process, which can delay the injection event - ECM compensates for that based on component specs
All high-pressure fuel lines between the rail and the injectors are of the same length and inside diameter to ensure equal-duration injection events, cylinder to cylinder.
Correct high-pressure fuel line usage and installation is critical to smooth engine operation.
FUEL MANAGER\FILTER
FUEL FILTER / WATER SEPARATOR
DESCRIPTION
The fuel filter/water separator assembly is located on left side of engine above the starter motor. The assembly also
includes the fuel heater, Water-In-Fuel (WIF) sensor and a screened banjo bolt attached at the bottom of the fuel
filter canister.
OPERATION
The fuel filter/water separator protects the fuel injection pump by removing water and contaminants from the fuel.
The construction of the filter/separator allows fuel to pass through it, but helps prevent moisture (water) from doing
so.
Moisture precipitates out and collects at the bottom of the canister.
A screened banjo-bolt is attached to the filtered outlet at the bottom of the fuel filter canister to provide additional filtering for the high pressure fuel system components.
A Water-In-Fuel (WIF) sensor is attached to the lower side of fuel filter housing.
A fuel heater is installed into the top of the filter/separator housing.
WATER IN FUEL SENSOR
DESCRIPTION
The Water-In-Fuel (WIF) sensor is located on the side of the fuel filter/water separator canister.
OPERATION
The sensor varies an input to the Engine Control Module (ECM) when it senses water in the fuel filter/water separator.
As the water level in the filter/separator increases, the resistance across the WIF sensor decreases. This
decrease in resistance is sent as a signal to the ECM and compared to a standard reference value. Once the value
drops to 30 to 40 kilohms, the ECM will activate the water-in-fuel warning lamp through CCD bus circuits. This all
takes place when the ignition key is initially put in the ON position. The ECM continues to monitor the input while the engine is running.
FUEL HEATER
DESCRIPTION
The fuel heater assembly is located on the side of the fuel filter housing and internal to the fuel filter housing .
The heater/element assembly is equipped with a temperature sensor (thermostat) that senses fuel temperature. This
sensor is attached to the fuel heater/element assembly.
OPERATION
The fuel heater is used to prevent diesel fuel from waxing during cold weather operation.
When the fuel temperature is below 45° ±8 F (7°C), the temperature sensor allows current to flow to the heater
element warming the fuel. When the fuel temperature is above 75° ±8 F (24°C), the sensor stops current flow to the
heater element.
Battery voltage to operate the fuel heater element is supplied from the ignition switch and through a solid state
device in the IPM.
There is no Fuel Heater Relay - fuel heater element and solid-state device in IPM are not ECM controlled.
The heater element operates on 12 volts, 300 watts at 0° F (-18° C).
A malfunctioning fuel heater can cause a wax build-up in the fuel filter/water separator. Wax build-up in the filter/
separator can cause engine starting problems and prevent the engine from revving up. It can also cause blue or
white fog-like exhaust. If the heater is not operating in cold temperatures, the engine may not operate due to fuel
waxing.
The fuel heater assembly is located on the side of fuel filter housing and internal to the fuel filter housing.
The heater assembly is equipped with a built-in fuel temperature sensor (thermostat) that senses fuel temperature.
When fuel temperature drops below 45° ± 8° F (7° C), the sensor allows current to flow to built-in heater element
to warm fuel. When fuel temperature rises above 75 °± 8° F (24° C), the sensor stops current flow to heater element
(circuit is open).
Voltage to operate fuel heater element is supplied from ignition switch, through the solid-state device in IPM, to fuel
temperature sensor and on to fuel heater element.
The heater element operates on 12 volts, 300 watts at 0 °F (-18° C). As temperature increases, power requirements
decrease.
A minimum of 7 volts is required to operate the fuel heater. The resistance value of the heater element is less than
1 ohm (cold) and up to 1000 ohms warm
FUEL TRANSFER PUMP
ELECTRIC FUEL LIFT PUMP
'03-'04 trucks have a Carter sliding-vane type lift pump attached to the fuel manager head on the engine, supplying ~15psi pressure, internally bypassed, with an internal pre-filter screen
'05^ trucks have a rotary-vane type lift pump in the fuel module in the tank, supplying ~ 9psi, externally bypassed, returning excess fuel to the tank, with a pre-filter screen
DESCRIPTION
The '05^ fuel transfer pump (fuel lift pump) is part of the fuel pump module .
The fuel pump module is located in the fuel tank.
The 12–volt electric pump is operated and controlled by the Engine Control Module (ECM).
The ECM controls a relay in the Intelligent Power Module (IPM) for transfer pump operation.
OPERATION
The purpose of the fuel transfer pump is to supply (transfer) a low-pressure fuel source from the fuel tank through
the fuel filter/water separator to the high-pressure fuel injection pump.
Check valves within the pump control direction of fuel flow and prevent fuel bleed-back during engine shut down.
Operating pressure is 9psi @ 50gph, maximum current flow to the pump is 5 amperes @100 percent duty-cycle..
The transfer pump is self-priming: when the key is first turned on (without cranking engine), the pump will operate
for approximately 2 seconds and then shut off (Note: When ambient temperatures are cold enough to cause the
intake air heaters to operate, the fuel lift pump will operate during the entire intake air pre-heat cycle). The pump will
also operate for up to 25 seconds after the starter is engaged, and then stop if the engine is not running.
A safety feature ensures the pump will shut off immediately if the key is on and the engine stops running.
The fuel volume of the transfer pump will always provide more fuel than the fuel injection pump requires. Excess
fuel is returned from the injection pump through the COV overflow valve back to the fuel tank.
The oem lift pump is of the flow-thru-when-failed type - the internal gearotor lift pump in the CP3 will pump 20" vacuum, and is designed to pull fuel from the tank thru a filter head - if the replacement aftermarket remote lift pump is not flow-thru, the engine will stop when the lift pump fails.
Always be sure the replacement LP is flow-thru type
+1 I came accross a lot of those incomplete posts as well while researching this topic when having similar fuel issues (extremely frustrating when u have a broken down truck). This is a great contribution to this topic!
All, ok I am back with additional input; I got tied up for the weekend with family activities but managed to do some of the troubleshooting with the FCA side of my plan.  I determined that the old FCA is not failed and operating the same as the new FCA:  It has the same continuity checks as the new FCA (4.1 Ohm +/- .1 Ohm and no grounds), vibrates/buzzes consistently the same as the new FCA, and while in hand I could see movement of the internal shaft/what I believe could be a valve seat moving. (I believe it is operating, the buzzing/valve seat moving as observed from the end looking down the center hole, that is observing silver metal coming into view or valve cylinder moving closer when buzzing, then darkness when not buzzing or the valve cylinder moving out of view or further away).  I found an excellent article on modifying an FCA but more importantly helps to understand its directional operation: http://relentlessdiesel.com/forum/viewtopic.php?t=5.  Based on this article (great pictures), the FCA is in the full open position at rest., i.e., the largest part of the triangle opening on the valve cylinder is aligned with the inlet holes on the FCA exterior shaft (three holes) and therefore passes maximum fuel thru the valve and out the center hole on the very end, which in-turn sends fuel onto the inlet of the CP3 high pressure side of the pump.  This may correlate to the P0088 code when the FCA is unplugged and engine is started, and because the ECM is controlling injectors at idle speed, the rail would be at an elevated pressure above what is needed for idle (i.e., set pressure of approximately 6,000 psi).  This is of course the case if no fuel is returned via the COV (because assumed failed) to the fuel tank causing maximum amount of fuel being sent to thru the FCA to the high pressure pump of the CP3.   The FCA was observed to vibrate/buzz when the ignition key was in the ACC position, and then there is a delay to ceasing to buzz/vibrate when the ign sw taken to off position for about 5 - 10 seconds delay.  The ECM is obviously sending a signal to it by this operation, so the ECM is without any issues from the best of my assessment.  Lastly, I confirmed that the truck would crank/start/run (at idle, approximately 700 rpm) with the New FCA disconnected  too (this really doesn't add any information since there would not be a difference between the old FCA being installed; there is no electrical communication to the FCA affecting the start) and of course it also throws the P0088 code (and the expected P0251 code).  I however did not remove the new FCA and change it back over to the old FCA in order to continue using it and keep the new one as spare.  I see no need to worry further about the FCAs.  There is one question to ponder, and it is based on the technical article explaining the FCA is directed by the ECM to full open (full rail pressure setpoint) during startup for up to 30 seconds while being started,  however  when it is disconnected from the ECM (no power) it must physically be full open from spring pressure.  This doesn't explain the buzzing/vibration and how the ECM is maintaining the valve full open?  I can't correlate what the buzzing of the solenoid is doing when connected to ECM during ignition sw in the ACC position.  Anyone that can make sense of this would help close out this aspect of the FCA operation.
Now, that I have continued to study the Fuel flow chart I put together and the fuel technical article, I can not find another failure mode associated with the P0088, high rail pressure code than the COV component that does not throw its own sensor connected code (this is an initial thought that still needs to be verified by going thru the list of all of the ECM codes).  However, there is a suspect failure of the CPS that feeds a signal into the ECM (per War Eagle), which is used by ECM to generate the control signal to the FCA as referred to in the above technical article too, as well as from the electrical prints I have reviewed from my CD service manual drawing (it is an input in addition to the several others form the prints of which two inputs could potentially cause full fuel flow to the rail/p0088 code; i.e.,. the rail pressure sensor (ruled out since it was just replace and is not throwing a code which I did get when it failed on me previously; and btw, it did not produce a crank/no start condition), idle throttle position switch, and/or accelerator pedal position sensor).  The big challenge to overcome, is why the CPS (which I confirmed on the electrical drawings is the Camshaft Position Sensor (CPS) - and according to War Eagle can cause sudden engine shutdown (but did it throw a code War Eagle???)).  With believing there are codes specific to these sensors, the COV is the only sensor that can cause a P0088 code and not a code of its own (thanks to input from Ed 5.9 above) and cause a sudden engine shutdown without throwing a code.  So I will test the output of the discharge from the COV to the fuel tank for flow during start up, which I would expect to see none if it is the cause of my engine no start/sudden shutdown condition experience on the highway.  If ok, then I will be without any logic for another suspect component downstream of the CP3 output or from these other sensors. PS - War Eagle it would be helpful if you can give me any insight into your CPS failure and whether the shop identified any related codes or did you have a code reader at the time and verified that there were no codes???  This would be very helpful and provide the logic I am looking for to confirm that this is a suspect component failure next.  Thanks, and btw I have the new COV and would like to just put it in and get immediate feedback, but will test its output from the current one installed before removing to inspect and replace it out ... in the spirit of being disciplined to following thru with the logical testing that my troubleshooting thoughts and plans are directing ...lol.!
Edited by gudge
Im in the middle of a job now but when I'm done I'll look around in my garage for my old FCA that started failing causing idle surge. I'll let you know if I find it. If I do I'll cut it open and post pics..... stay tuned !
By the way you are a man of great patience, I could not hold in my hand the part that may resolve an issue in the name of proper diagnosing, God bless!
