What components can a map sensor affect?
None of the above. The ECM has two modes of operation. 100% duty cycle for running engine and 50% duty cycle (modulated) during cranking of the engine. MAP sensor only affect the timing and fuel of the VP44. Doesn't affect the performance of the lift pump.
What your seeing is high fuel demands and the fuel pressure falling. So what is happening is the demand volume is higher than the supply volume so the fuel pressure falls. Then is reverse when load is reduced the demand volume reduced and supply volume over whelms the VP44 so the fuel pressure rise and overflow valve opens more.
