- Replies 8
- Views 2.8k
jlwelding 3 posts
Mopar1973Man 2 posts
CSM 1 post
JAG1 1 post
I may not explain this good but here goes. I need to test the alt for feed back, my apps or something is causing it to feel like its running out of fuel. It doesn't cut out hard, it has that running out of fuel feel to it. The more you mash the pedal no help its dead, let it all the way up then start back into it and it will either accelerate or you have to let it up again then it will run ok. It may run all day and never do it again or it has done it 1/2 dozen times. No codes, well it has a 1693 but nothing in there. I have put three diff. apps on and they all do the same.
Fuel filters are clean, fuel pressure is 15. I just cant find the write up.
Thanks
