Well guys I'm needing a bit of advice. Looking to knock the drone out of the cab of my truck while keeping the sound from the tailpipe. So which FTE resonator should I use 17 inch or 30 inch?
I have a MagnaFlow SS 4 inch flow through muffler I just want to knock the drone out.
3 minutes ago, CTcummins24V said:
I forget which one I used, but it helps! I installed a 5" exhaust, 4" hx40 downdpipe and muffler and the drone and noise was crazy! FTE resonator took care of all the problems. I'll measure today, but I think I just used the smaller one.
Thank you sir. Let me know what size you used.
Ever find out which size you ran? I've got a 30 inch sitting in my apartment made of 409 HD stainless.
5 hours ago, Mopar1973Man said:
30" inch. I just installed a Diamond Eye 4" exhaust with 30" muffler on a 1995 that had a 5" straight pipe with serious drone issues at 65 MPH. Now its whisper quiet in the cab. The exhaust note is way better.
Good to know. I'm running 4 inch stainless after the down pipe with a MagnaFlow stainless muffler but the drone is killing me.
3 hours ago, CTcummins24V said:
Ooops sorry. 30" length, 5"
That's okay that's what I have sitting here in my living room waiting on a little time to pull some piping and mock-up a good V-band mounting location. I'm thinking to install it closer to the down pipe to make it easier to remove. Just need to figure it out and have a welder finalize the welds.
