- Replies 42
- Views 12.5k
The_Hammer 20 posts
JOHNFAK 5 posts
Mopar1973Man 4 posts
TFaoro 4 posts
Honestly If I had it over again I wouldn't have spent the money. I dont feel my truck drives that much better. Of course Carli tell you you need there rear leafs. The ONLY guy that I know that ran the
@Mopar1973Man I'll be sure to document the entire process and list the materials and parts required. JOHNFAK has agreed to give me a hand in getting the dimensions right, which will definitely ta
Stock suspension is pretty decent imo. It is going to take a lot of trial and error to get equal suspension towing capacity with a lift. However, if you don't tow at gcvw, that isn't a priority and
Currently I have a 2" leveling kit installed that consists of 2" steel coil spring spacers and add-a-leafs in the rear. I'm not happy with my ride quality and will be changing some things up to make it right.
First up is building a pair of shackle reversal brackets and shackles. This will accomplish two things:
1 - Converting from the stock tension shackle to a compression shackle improves ride quality without sacrificing load capacity.
2 - The added lift will allow the removal of the factory lift blocks and add-a-leafs, resulting in less axle wrap and a smoother ride.
A couple of things to take in to account is that as you drop the rear spring mounting points down it also changes the pinion angle and moves the axle foward. This can be taken care of with an offset 1" zero rate and 5° wedge, or an offset 1" zero rate with a 5° slope machined in, nether of which will adversely affect load carrying capacity or durability.
The front suspension is a bit more involved with multiple options for optimizing ride quality. The most common route to take is to install extended control arms, followed by long arms, and finally long radius arms. I'm thinking about going with long radius arms due to the fact that I'm not running much lift and have minimal clearance to work with. The goal is to have the arms as parallel to the ground as possible, which equates to a smoother ride. The only negative of a long radius arm set up is that it doesn't flex as much as a 4-link, since my truck doesn't see any serious off road use that's of no concern to me.
I'll be starting on the shackle reversal very soon as I have finally got my hands on enough 1/4" plate to build them. I will be l taking pictures and documenting the project as I go along.
