No high pressure at vp when cold unless hotwired
I would Leave it outside to have the no start condition. Have dude crank the truck. And check every circuit at the vp. Find the missing power or ground or bus. Then trace that wire back to the module to see if the wire is good. If the wire is good and ur not getting ur power or ground. Module is bad.
Thanks for the diagrams. The ground over on the turbo side thats the PCM ground right ? I see there is a fuel pump relay where abouts is this loacted ? Im no electrical guru so please bear with me lol. I assume the ecm triggers the relay which is supposed to send power to pin 7 ?
Fuel Pump relay in the PDC.
This is the master ground on the passenger side battery. There is no body mounted ground for the ECM, PCM or VP44.
Correct. Take notice this is a bit more confusing but the grounds all come to that G115 which is my picture above. Fuel Pump relay is in the upper right corner triggered by the ECM.
http://articles.mopar1973man.com/images/2ndgen24v/wiring/2002-Dodge-Wiring-pg3.jpg
13 minutes ago, Mopar1973Man said:
Gelled? :think:
Same fuel in the tank as sunday when i dropped it off. Was -10 sunday and wasn't gelled. today its maybe -5 out today.All kinds fuel at the IP inlet and no air. I just wish there was a code.
Edited by moparguy55
That isn't a bad price.  There will be some engine differences though in terms of sensors you will have to work with for an 02.
I wouldn't trust the VP on any junkyard motor.
Unfortunately im on the other side of the border. Best price on a bosch VP up here in canada is almost $2000 tax in.
So DAP and Vulcan are the 2 recommended vp vendors ?
I was looking at bluechip and Vp44pumps.com as both had 2 year warranties. Bluechip was only place that warrantys a wire tap via the stealth cover from what i found.
Im sceptic to buy a new VP up here as i dont know if the whole pump is rebuilt or just the defective part and rebaged.
And yes the electric stuff after the p pump swap is whats making me hesitent. I found a running 12v for $900. thought all i needed was the special fuel lines and a boost elbow. But i like the power with the juice the truck has and virtually no smoke even on level 5 tromping on it. Thinking about it now maybe the vp was failing. Shouldnt it pump a lil smoke on a hard stomp on level 5 ? On the highway tromp it and im not sure you could even call it a haze from the exhaust. like slight tinge of black for 1/2 second.
Here is Vulcan at barely over $1,000
http://www.vulcanperformance.com/Bosch-VP44-p/vp44.htm
Here is DAP...
http://dieselautopower.com/bosch-027-vp44-fuel-injection-pump-standard-output-235hp-wire-tap-voids-2-year-warranty-vp44027/
Oh... BlueChip you have to pay at least $1,800 for a pump with a new PSG unit where both list above come with new PSG and been calibrated on a bench.
I dont want to knock the blue chip pumps because I have one. Bought it about 5.5 years ago for near $1700. At the time it was the only pump that I found that came with new electronics on it and that was a the main reason I bought it. I have 143K miles on it with no issues and it has been on a 2 stroke diet 90% of its life. That being said it has not had any longer service life than many others here for me to say it was worth the extra. Blue Chip is a good company and has given me good service thru the years I have owned.
Golden info guys much appreciated.
This part on the DAP disclaimer has me wondering
Core:
Core deposit of $400 required unless core sent in advance. If a rebuildable core (ie. not seized, damaged, contaminated, disassembled) is not received in 30 days from date of shipment a reduced core credit of $200 applies for late cores. International orders have 45 days. IF YOU PURCHASE AN HO 245HP PUMP, YOU MUST RETURN AN HO 245HP PUMP. ANYTHING OTHER THAN AN HO 245HP PUMP RETURNED WILL RESULT IN 1/2 CREDIT.
So if it was crap fuel that ruined the pump on the truck they deem the core not rebuild able ?
Id probably not wire tap until the warranty is up.
