Excessive surging
OK guys I believe I'm loosing my apps due to while driving at less than half throttle it starts surging and some times bucking. No codes present and with the scanner my apps signal seams to be a little too jumpy in my opinion. Truck is the one in my Sig. Are there any other thing that would give this same issue
Excessive alternator noise could cause issues driving the ECM nuts. Bad ground on the passenger battery be aware of the cable clipped to the battery tray. That is the master ground for the ECM, PCM and VP44. Typically APPS sensor that is going bad typically throws a P0121, P0122 or P0123. Very rare does it just get jumpy because its bad.
If you want to test that again use a analog volt meter and probe the signal wire. It should rise smoothly without jumping.
