Well I finally got a chance to install my 150's from jkidd. My first time changing them out on on of these. Read over Mikes write up and went with out a hitch. I must agree though the lines on #6 are a SOB! Worst part was trying to get the nut threaded up again! After assembly bled a couple lines and all's good. the truck seemed to be a little quieter and idled smoother. Took for a little test drive with my PM3 turned off. It felt very similar to running with my box on PL5. Now I have to say I didn't ripp the thing but I did feel pretty good. Rolls a little coal if I nail it. Hopefully when I get the HE351 installed will be that much better. :)
I've only put approx 70mi on them so far. However I do see a slight improvement on the mpg (scangauge II). EGT's are a little higher but to be expected with the stock HY35. My HE351 retrofit should take care of that. You can definitely roll coal if you desire. But a careful foot and clean as a whistle.
uber racing...how are the injectors treating you?
I've been quite happy with them so far . You definitely need more air with the 150's. My HE351 hopefully will take care of that. Millage up a bit. Quieter. All good stuff. Also the pricing from jkidd was excellent.
