Trans. leaking at inspection cover
Hi, my truck is stored for winter. I need to rebuilt my trans. this spring cause last autumn I had a leaking problem at the inspection cover. The trans. shift Ok but in O.D I felt a little slippage .   I was thinking of an oil pump seal or maybe the converter????   If someone can help.   47re transmission. just been rebuild 2 years ago by me but had a problem with a hose to the cooler. It disconnect and lost all the oil. After that the trans. run fine for about 1 month until I work on adjusting TPS and got this leaking at the cover!!!  the shift become more strong like 1-2.  like a shift kit after TPS adjust and before the leaking problem .. .    I install a transgo diesel kit  in my rebuild 2 years ago!!
What you think???                  Sorry for my text and my english, I'm not so good..   Try my best
Thanks  Francis
And new single disc converter at same time than the rebuild
No matter how you want to slice this you going to pull the transmission down and inspect the seal and replace it. But I will make mention of the possibly of input shaft bearing issues can do this too. What will happen is you'll replace the seal and get just a few days to maybe a week and the seal will leak again. So this is another possible problem too.
Thanks guys!!  I'll need to check it and rebuild it this spring...  Only thing I don't understand is why it's slipping in O.D.?   Cause I lost a little pressure and the OD clutches slips..     I remember that I had a little lost of line pressure.  It was around 110 cruising when OK but now around 100 psi
I'm skeptical of single disc torque converters. I don't think they can handle the torque from a cummins, there just isn't enough friction material/surface area. If your line pressures check out/valve body is good, and your overdrive unit was recently rebuilt, I would bet on your TC for the slipping issue.
