I'm not really a fan of seeing a big tip on exhaust or seeing  the exhaust pipe at all. So.. a few weeks ago I cut the last few feet of the exhaust for an axle dump. What I didn't realize was how much louder it would be and how much drone and vibration would come as a result. :doh: I had a hanger/support installed but its a couple/few feet up from the end. So over the axle.. there's no support. I don't mind it being a little louder but the drone and vibration is driving me nutz <--- no pun intended. Do you think another hanger near the end would help alleviate this.. or no?
  • Replies 23
  • Views 12.6k
  • Wild and Free
    Wild and Free
    At that point you will be in need of a long resonator or a very good muffler or both to eliminate that noise. On my 2010 Hemi a couple years ago I had a guy back into my right rear and kink the e
  • Patience my friend... cut slices down the outer pipe, as many as you need. Then use a small chisel to bend the tabs out. Then twist the pipe until it comes loose. If you need to squirt WD40 in the joi
  • CTcummins24V
    CTcummins24V
    Not a driving, yet.
  • 3 years later...
Pulling up an old thread.
I run a 5" 30" fte alone and have the quitest coolest sounding truck I've ever heard.
5" pipe from 4" down pipe back.
Fte placed as far forward as I could get it.
Edited by Evan
