Sight Glass for Trans and T case
The hose will only bend so far before it pinches and then that would be bad.  Plus I cant have it pointing straight up and down because then the fluid will always fill the entire length of the tubing due to the height of the fluid level kinda proving pointless unless the fluid level drops well below safe.
So I ended up with a radius curve to allow a real time constant visual confirmation of the fluids level and condition.  Seems to work.....
Important to point out is that this isnt your everyday poly tubing you find at the hardware store but rather FEP tubing which is rated -100*F to 400*F. :thumbup2:
Very true.  Good thinking.....but how would I fill it back up? :thumbup2:  I guess I could put a tee on top too.
Really what I planned on doing was later on converting half the fittings to JIC so I can easily take off the hose, but after searching for weeks on end I was getting bored of trying to configure something from internet pictures and just needed whatever I could get to mock up what I have.
