Maybe a little off topic here but I reckon it'll get the attention of the right folks here...I just completed my Cummins swap and I'm wiring in the dodge pcm to get through my emissions test. My question for you dodge can junkies is can my Allison tcm and the dodge pcm share the same obd plug? I have already checked and the same pins are used although I am not able to find out if the same pins are being used for the same functions or if that even matters. If they are both hooked up to the same obd will the emissions control equipment initiate communication with the pcm, and the efilive autocal I use to tune my transmission talk to the tcm, or will everything just end up a jumbled mess? I do know my tcm speaks j1939 but I'm not sure what protocol the autocal uses to communicate with the tcm. You guys will know far better than I what protocol is used by the dodge pcm at the obd plug. What do you think?
I know you can get a splitter for the OBD2 plug but I'm not sure if that helps you.
