anyone ever thought about retrofitting tapshifter in place of our autos?
I like nice OEM style buttons to control things,  It could be EB or TC lockup or whatever.
Or the dodge version
2016-ram-2500-3500-heavy-duty-6.7-cummin
I looks like it might be a pretty easy install.
Anyone ever been down this road?
  • Replies 4
  • Views 1.7k
Depends on what you have.  I could use the buttons for  + / - to manually set vane position, or curve type, or EB or lockup.
You may even be able to control shifts IF, BIG IF, you were able to control solenoid pressure somehow.  not sure I want to R&D that one but it should be sorta possible.
Talk to Dynamic he would tell you...
already have.  I would need to make volts on the solenoid through gear shifts vs tps.  then bypass the pcm and adjust the solenoid pressure to make shifts happen.
again I dunno if I want to do the R&D on that one, but in theory....
