Grossing 16-17k in the Northeast, should I expect more from truck?
Thanks. Had to go reread some old posts to correlate what 45mm3 would mean with weird duration labels, but I see now that’s about 32% load.
Other than using the calculator as a guide, listening for rattle, and watching for a haze, what can I do to make sure I am at safe but efficient timing values in that 30-50% load range for towing?
  • 3 weeks later...
Heading out for the first wheeling trip of the year today. ~900 miles. Truck and trailer came to work with me today and leaving right from here.
I'm not sure if it is the turbo or the tune - probably both - but I am feeling an improvement equal to or greater than what I felt going from stock tune to Jr. It feels much more comfortable cruising and soaking up medium sized rolling hills at 65-70mph now.
Question on EGTs. I am really regretting letting my GF borrow my laptop for a few days because I can't show a screenshot of the timing map I'm running. My cruise region 30-60% load timing is very similar to the UDC Jr sample tune you posted over on CompD (AH) and maybe a hair higher in some areas. In the higher RPM, higher load areas (5th gear grade climbing) it runs very close and just under the SW3 Jr sample tune and is also more gradual getting there (I think your advice was 'less static').
On medium hills at 70mph and ~60-80% load, I am seeing 1000-1100* and 25-30lb of boost. 4th and 5th gear steep on ramp at the same 85% load to about 2700rpm and I'm getting to 1250-1300 by the time I shift, so only briefly seeing that.
Again... really wish I could post a screenshot, but the lower EGTs in the 60-80% area has me a hair concerned and wondering if I should revert back to SW3 for the trip. There is one area I hear some timing/injector rattle while running through the gears at higher loads that I haven't identified yet but it is very brief so I am not too concerned there. Mostly concerned about 5th gear sustained 1200-1300* based on SW3 sample high RPM/load and 1000-1100* letting cruise control do work cruising smaller hills on the highway.
Edited by JPhauler87
4 minutes ago, AH64ID said:
How does your fuel map compare to SW3 sample? Or Stock?
Haven't touched duration and still using Jr so no pressure, either. Timing as described, maxed out WG map, little more aggressive torque management than SW3 for smoother operation is all I have done.
Trying to avoid turning my pistons into puddles of aluminum! Long trip and first time operating my UDC tune in the higher load area of the map where I suspect bad things are more likely to happen, if they are going to happen.
I suspect that my changes are not drastic enough to really cause that to happen, and I do not drive aggressively. Mostly looking for a sanity check, I think you've given me one. :)
I ended up averaging about 9.8mpg on that trip holding 70mph on all but the largest grades.
Shorter NH trip with the trailer a few weeks ago netted 10.7mpg traveling at 65mph.
I got a VIN locked SSR for a song and paid to get it unlocked. So, I have been playing with rail pressure now. I should take some screenshots, but I basically have it increasing with load and RPM pretty steadily with a dip in the 0-37% 1800-2200 load area to try to work on unloaded economy. (Sold Jr and am <$600 into everything tuning related now.)
Duration is still 100% stock.
Was around 14.5k psi in the unloaded highway cruise area with 11* and could hear a very faint rattle. Best I was doing with the more aggressive timing was ~16.5mpg. I have been driving it everyday the last week or so and netted a solid 18mpg on a 470 mile tank. Best ever so far with for this truck. Fingers crossed it's repeatable.
Last night I lowered the rail pressure to about 13.5k psi in the cruise area with about 10* max timing. Still the faintest rattle cruising, but EGTs seemed to be a hair lower and the lie-o-meter was reading 22mpg by the time I was to work and it has been pretty consistently 2mpg optimistic since I uploaded the first tune on my Jr a while ago. Too soon to tell though.
All my unloaded highway driving is moderately hilly with cruise at 65mph.
The rest of the timing map is now verbatim what came out of the timing calculator except where I bumped it ~1* in the highway cruise region. The next time I am hooked up to my trailer I will be keeping an eye on how it acts in the mid load range where it cruises with the trailer. I think I was around 5-6* there coming right off the calculator. For the upper RPM and load areas I guess I am seeing very little reason for aggressive timing there since that is not a place I spend much time. And when I am there, I just want the piece of mind that I can be there without worrying about cylinder temps. I may experiment with dropping the rail pressure in the trailer cruise region to see if it helps as much there as it seems to have helped elsewhere in the map.
I was initially intrigued by using the SSR to turn off the pre-injection, but I am not sure that will be worth the trouble. Maybe if I find myself with some time to play with it I will experiment, but doesn't sound like it is a very well developed feature.
Rear pinion seal has been leaking since halfway to Utah, finally dealing with that this weekend. Have been getting a really annoying shutter on take off since I owned the truck. Cured it by shimming the carrier bearing... then hooked my trailer and found it was worse. Bah! I think I'm going to be saving my pennies for a one piece alum unit. ($$$)
  • 2 months later...
Driving at the speed limits I'm netting 18mpg daily driving and 11mpg towing. Happy.
Working on dialing back pre boost smoke. Not bad at all unless I'm making an aggressive left turn into traffic or take off hard. Timing is pretty retarded in the low RPM high load regions. Working on dialing back duration a bit there now, not sure it's helping. Any advice?
I hate to say it, but UDC Pro is what you need. There just aren’t enough tables in UDC Basic. Most of that comes from the base tables that are adjusted by MADS, especially since you’re using SSR base tune.
Dialing duration back just makes you run a higher load, and then you’ll also effect the duration at other rpms too.
Timing and rail pressure are the best adjustments for that in UDC Basic, especially with stock injectors.
Edited by AH64ID
  • 4 weeks later...
