Funkyness 4wd
4wd seems to make a funny noise if i get going beyond 55mph. Like I'm riding on the rumble strip. Anything else, runs just fine.
You may recall i had to repair the shaft got a used one then redid the u joints on that. Could it be out of balance?
Are you locked in 4 hi when this happens?
will it do it in 2wd?
my guess is if you got a used one or had to repair it that is probably your issue, If it is I would remove it before something catastrophic happens. broken driveshafts or u joints at hiway speeds usually don't turn out good.  If you remove the driveshaft and problem goes away then you defiantly need a new shaft, A rebuild by a driveline shop would be your best bet.
Personaly if if your getting that much vibration at that speed I don't think balancing is going to help
Edited by 01cummins4ever
I guess since yours does it in 4wd I would do the reverse and see if maybe the collar is not strong enough to hold 4wd.
Go from 4wd to 2wd and see if it goes away.
I also noticed that if the  tailhousing shaft bearing is loose the entire shaft can move back and cause the synro to grind in the transfer case.
