P pump not able to tune
I have 150 hp injectors, timing set to 16 degrees, 191 dvs, i ground the fuel plate to #0, set the housing and plate all the way forward and i cant even get a haze of smoke (just to see if i am getting more fuel). Ive tried
adjusting smoke screw and nothing i do is making a difference. What could be wrong? I just want to be able to tune this thing right.
Put the plate at center then move it back a hair or two, then you need to bust the Allen head off the top and using a marker or something mark one of the fins , spin it one full turn towards the engine  with a flatip untill at your mark , if you have adjusted smoke screw and still get no smoke this is why  or you went wrong way on screw
