Wheel question
  • Replies 7
  • Views 3.5k
I believe they might use the hub to center and lug nuts are flat. Or maybe it's ford I'm thinking of.
should fit. might rub a little but should clear
Those must be Power Wagon wheels, they look good. I have the 18 inch 4th gen wheels and besides a little rubbing up front they seem to work fine. I have heard others say the hub wouldn't fit though as the newer wheels have most of the hubcap integrated into the wheel.
This is the same size tire I run now, only on Nitto.
I'm worried wether the 4th gen wheels will fit a 2nd gen tho.
I think the rear hub on our trucks sticks out too far and would hit the built in hub cap on the newer wheels. Might need wheel spacers to fit them. Only speculation, I thinks cumminsforum has a thread on it.
I've heard that too but they fit my truck just fine. It must be because I have a Dana 80 rear axle instead of a 70.
