- Replies 11
- Views 3.3k
Ilikeoldfords 5 posts
JAG1 3 posts
Mopar1973Man 2 posts
IBMobile 1 post
I had that same issue with a Ford truck I had. If I got on it hard going up hill the fuel pump couldn't keep up. I would pull over and all it could do was sit there at an idle, I let it sit to catch
I would swap the fuel pump relay with another relay in the PDC and Fords have a fuel pump inertia kill switch under the dash that you might want to check. It's been my experience that a high pressure
Hey there guys. I got my self a cheap rig from a buddy. Its a 2002 F-250 5.4L gasser. Its got a lot of miles on it but I got it for a good price. I am having an issue with it that I am not sure where to start checking things. I picked up the truck a couple weeks ago and its ran fine until today. I should specify I have been doing some maintenance things here and there to the truck. Changed fuel and air filters last night. Changed the cruise control disengagement switch and harness plug also.
After about 10 minutes on the freeway today the engine just cut out and died. Got pulled over, shut the key off. Cranked it over and she started right away like normal. Then it was fine the rest of the trip. We did about 30 minutes of slow forest service road driving and it ran fine through all of that. Then on the way home it died twice on the freeway. Both times it started right back up like normal.
I am thinking maybe a fuel pump issue. The old fuel filter was pretty well plugged. Maybe now that everything is free flowing the pump cant keep up at highway speeds? I have not checked fuel pressures or anything. I also dont think its a short or wiring problem somewhere otherwise it would have cut out on the forest service roads which were more bumpy than the freeway.
What do you guys think??
