Iquadbt issue
I just got the iquadbt for my old adr seams to work okay can tune a little but doesn't show any timming and the gauges seam to freeze quite often. Also the analog part of the Guge is no where to be found. Any one seeen this befor?
  • Replies 8
  • Views 4.6k
  • Ensure you have the v2 base flash on the box under the hood.  Once you have that then you need to select the v2 vehicle profile.  One will not work without the other.
My Azpen A729 Android Tablet does the same thing with the missing needles.
As for the crashing make sure you are up to date on the mobile app and the flash on the Quadzilla. Everything should be in the download area.
Okay so I guess I need to flash it quadzilla said nothing about that I saw it in the other forms from back in late 2016 so wasn't sure if it was still needed
yep,  the phone side can only display what the box is sending out.  The older v1 tunes do not show timing value.  You will need the V2 tuning base flash.
Then you choose the v2 vehicle profile 2.5
Then you can tune and see timing and the canbus fueling command.
Okay awesome. Who runs the quadzilla FB I asked him what I needed to do to v2 tune he said just plug the iQuad in
dunno.  He prob assumed you had boughten a box recently.  New boxes are shipping with V2 pre loaded.
Makes sense. thanks for all your help!
Yep, poor communication on our part. You do need to flash the box as well.
I did send that to you (this morning) and yes, mopar1973man is the other person who had the same issue. I've honestly not heard of anything outside of you two with that issue.
