Long list of voltage codes
Hopefully I can get some clarity from you all, as I have been scratching my head.
I have been posting on other sites throughout the years and have had good luck, but seems like this is the place for good electronics info.
Truck info:
2002 2500
6 speed
Smarty
FASS
4" Turbo Back
Prodigy Brake Controller
BHAF
List of codes from Smarty
P0121
P0122
P0123
All APPS voltage codes, but I am getting high and low voltage codes :think:
P0177
WIF
P1475
P1480
Aux 5 Voltage high and low
P0342
P0342
Camshaft Position Sensor High and low
P1693
Companion code
P0500
No vehicle speed sensor
P0462
Fuel Sending unit voltage low
I am experiencing Dead pedal, surging and bucking while driving. Starts right up every time, but even at idle it has a mind of its own and revs up and down on its own.
The WIF dash light comes and goes when it's acting up or idling fine. The cruise light comes on and off as it's idling or driving. The most recent time the check gauges dash light came on.
I replaced my APPS sensor 2 years ago, about 20k miles ago when I was trying to diagnose issues. It was the VP44, so I replaced that. It has been running great since then, until now.
I have reset the APPS sensor with no luck.
I don't have the P0606 code for the ECM, but still seems like that may be the cause.
Any and all help is greatly appreciated. Thanks in advance!
Mine ECM went with the same symptoms and no 606 code. Many high and low volt codes, engine surging while out of the cab, temp gauge would sometimes peg from cold start in seconds and other anomalies. Have you checked for AC voltage out of your aternator?
5 hours ago, Red952 said:
Alternator is reading 14.05V.
I will start going through the sensor plugs. Would one sensor gone bad cause all these codes though? Seems odd that several of them would go bad all at once.
AC voltage is what I was speaking of.
Mine was fine one day and the next it all went whacky just like yours. I could not believe that all my sensor and what have you all went bad at once either. I was pretty sure it was the ECM. But since I am a member of the electronically challenged club I could not be sure. I did some diagnostics and every thing I did said this or that sensor was bad, the instrument cluster failed, and not sure what else, it has been 8 years or more. I swapped in a couple of the less expensive sensors and an instrument cluster I got at a junk yard to no avail. An ECM is what fixed mine.
 With that being said I would listen to what some others have to say. It is easy for me to spend your money and I dont want to lead you down the wrong path. I spent 2 months trying to figure mine out before I pulled the trigger. I am not sure anyone even here can or will say it is definitely the ECM. I did everything I could to avoid the dealer due to the cost. Not even sure you can get one from them anymore. You could call some and see if they can diagnose the ECM or not. A step I wish I had taken.
