Well I’m not sure what too say about this but I was gone for the weekend and got home last night. Drive to work this morning and it in to head home. I got on it in 6th gear and saw 28 psi of booost. Why didn’t I see anymore than 20 when I pegged it last time!? Prepping to replace map and reset apps in a little...
Also seems like it has quite a bit more power too but I’m not sure if it’s as powerful as it should be...
Just now, Me78569 said:
because the map sensor was old and worn out?
He never even changed the MAP sensor. It's possible the data from the sensor is too low and not reporting real boost. It could be a boost fooler problem of the Edge Juice. This boost fooler failure does happen...
We will be checking the boost cooler when I get my splitter
This happened before I changed the sensor...
17 hours ago, Marcus2000monster said:
Splitter is not letting juice and scan gauge connect at the same time.
Too much traffic on the bus. So... What I would do is start the truck with just the Edge Juice plugged in leave it idle for few minutes to settle down then plug in the ScanGauge II and it should hook up then.
There are only two things that cause dead pedal...
1. APPS sensor. Typically there is a P0121, P0122 or P0123 code with the dead pedal.
2. VP44. It could produce dead pedal like problems too but doesn't have to throw codes.
Now without read back over the entire thread did you ever do a AC noise test?
