- Replies 14
- Views 2.8k
Me78569 5 posts
mossyoak71 5 posts
Quadzilla Power 3 posts
kzimmer 1 post
Popular Days
Sorry I haven't posted anything, but just now getting it to run right. So I did order a new converter with higher stall, and put it in this past weekend. So I left the DDP125 injectors in, and it deve
The Quadzilla isn't doing anything at idle unless the high idle function is enabled and the high idle timeout has passed. I would personally get a higher stall coverter to fix your issues.
I finally got the DAP 7x.012 VCO injectors installed last night. I downloaded the daily driver 7x.012 and it is not showing up in the custom tunes. So I tried again and it said there was a file already. Also when I place the truck in reverse it sometimes dies, but when you put it in drive it is fine. Can the quadzilla help with that issue, and if so how. The Cummins is connected to the 5R110 that was in the truck. It was built by revmax, and had a stage 5 converter in it. I'm thinking I need to go to a higher stall rating, but not sure.
