- Replies 39
- Views 27.3k
Red Rambler 12 posts
Mopar1973Man 9 posts
trreed 7 posts
Dieselfuture 4 posts
Popular Days
I would venture to say you are fine then. Look into re-routing the breather and you'll be fine just fine. Using 2-stroke oil won't contribute to blowby. The vapor does have a heavy oil smell, cause t
As much as I don't want to shop at Walmart you can get oil there much cheaper then orilys, while you're there get some 2 stroke oil for adding to fuel, it's the supertech stuff in blue jug. Bigg
Also make sure you have no vacuum leaks if you have big vacuum leaks that will contribute to excessive blowby or at least it would seem that way. The crankcase vent mod that a lot of us did will
My truck has the stock crankcase breather bottle. It is making quite the mess and getting oil all over the underside. Got a few questions however as when I am sitting on level ground at a stoplight I see smoke coming from both sides of my truck. I can take my oil fill cap off and smoke comes out of that hole and I see smoke coming from my crankcase breather when I shut my truck off. It appears to be smoke coming from my crankcase breather but I wanted to make sure I possibly don’t have a bigger issue since I am getting smoke coming out of the valve cover oil fill hole. I don’t recall this issue previouslay but have noticed a stronger smell of oil as of lately as well. I don’t get any oil coming out of my valve cover, just smoke. I have been reviewing the crankcase vent mode, however it seems quite a few have done this mod due to steep grades, however I haven’t been on any extreme grades.
