Brake Boost
So I been having trouble with rear brakes (DRUM) real sensitive you just touch and you can feel them grab, rain, gravel road you got to baby them. Its like the pedal is right there at the top supplying rear brakes before the front disc. Well I installed new injectors and noticed oil leak under boost. Can this be the cause of rear brakes being so touchy?
Just a FYI I had two different trucks that had that problem and on both I found that the axle seals had failed and contaminated the shoes. One had no outside indication of a leak. Both I replaced the shoes ,the seal and cleaned everything and all was good.
