crazy fuel pressure & engine speeds
beren
23 hours ago, Quadzilla Power said:
What this means is that if you have larger tires and a corrected speedo via programming, you will probably never have the right trans slip ratio or gear, but the MPG calcuations should still be close.
235/85 R16 vs 265/75 R16 which is 1mm taller and 2 Rev/Mile less. But +3 MPH off at 65 MPH ??? Hua? Manual Transmission no slip...
One thing I'm noticing is the speed sometimes jumps around. Like it'll  jump 3 to 10 miles an hour high and then come back down. This is with smooth study acceleration also
Edited by beren
  • 2 months later...
On 3/9/2018 at 9:04 AM, Mopar1973Man said:
Nope, the water hammer killed the fuel pressure sensor. You'll need a new fuel pressure sensor and relocate the sensor away from the VP44. This is one reason my fuel pressure sensor is mounted near the ABS module this gives over 6 feet of tube run away from the VP44 and pulses fade with distance. I'm sunning an ISSPro snubber and a needle valve which the needle valve has no purpose other to close the line if a leak occurs.
So what did you do to move it, just get some ends and a length of fuel line? Do you think a small line would help to even out the pulses since it would stretch/absorb more? I just ordered a new sensor, gotta love eBay sales, I got 15% off :-)
