I have a 97 12 valve got home from work with coolant all over the a arm and coolant is foamy is it the thermostat housing leaking
Hard to tell where exactly it’s coming from truck doesn’t over heat or smoke doesn’t have power loss either
Cummins only uses a rubber o-ring for sealing the thermostat.
There is the little bypass hose on top there double check it. Check for cracks in the block and if you have a 53 block which are known to crack on the passenger side. There is the heater hose on the passenger side that might be leaking too.
The easiest way to chase leaks is on a cold dry engine. Pump up the coolant system with 16-18 PSI of pressure and watch for the coolant to flow. Flow the coolant trail back ot the source of the leak.
