Has anyone found a replacement for the bolt in the centre of the plug for the engine ECM that is bolted on the tappet cover.  I found that someone had broken the one on mine sometime in the past.
I Can't find a listing for just the bolt anywhere.  I went to the Dodge dealer and they Don't have any listing for the ECM or Plug let alone the bolt.
On 05/04/2018 at 11:00 AM, jlbayes said:
IF I remember this weekend I'll check mine and get info for it.
It would be appreciated.  I'm not sure if I actually need it as mine had been missing for an unknown period of time.  The bolt has a circlip on it so you Can't screw it too far into the ecm
