Gearbox Lower Seal Replacement
10 minutes ago, Mopar1973Man said:
Might have to call him on that... I know I got a seal kit for my old box but the rust was so bad. I sent as a core. I know he can do seal kits. The contact info everything is in his forum area. If you post over there it should bring him to the site.
Do you remember what it cost you? I found a kit from Advanced Auto Parts for $9 with 2 seals and a clip, of course I dont know what one of these kits consists of.
If your bearing is wore a seal won't fix it for very long. Do you have a gear box brace to keep that bearing from flexing beyond it's capabilities.
No. Its just leaking out the seal so I think all I need is a seal. The truck steers very well surprisingly, better than most 2nd gens so I believe all I need is a seal.
