99 Engine swap - engine year 55 block
When my 99 `s block cracked , Cummins removed everything from the 53 block and re installed it in a new 55 block with new piston rings and all seals , the engine id plate is on the timing cover that was re used , its off the original motor .
Only cost me 4300.00 for the labor , parts free , out of 100k Cummins warranty , 12 yeas ago , still hurts
