- Replies 11
- Views 8.9k
Mopar1973Man 4 posts
ofelas 4 posts
mountaindan 2 posts
JAG1 1 post
I would have the alternator checked it might have a bad armature winding that is killing the voltage regulators. Basically, in a nutshell, the charging system has been the same for years. Blue wire is
Run a dedicated ground from the VR to the firewall, assuming your existing battery/frame/body grounds are good. Also check the ground from the alternator to the front of the block.
Rare to see them... Yes, they are real people too. But just as rare as Hen's Teeth or Rocking Horse Crap.
I have a 1990 Cummins cannot keep a voltage regulator in it they will last for a couple of months, then will either short to ground or open up. It will either overcharge or not charge at all. I have been getting them from Napa,. Anyone with any ideas, help would be greatly appreciated.
