- Replies 10
- Views 2.5k
Mopar1973Man 5 posts
KOYOTE 3 posts
guesswho512 1 post
AH64ID 1 post
Well gang... I figured I'd share a experience with you all... I've got a home made high idle kit on my Cummins that electronically fools the ECM to thinking it cold and tripping the high idle software... But what was occurring is that as I drove down the highway I would listen to a random cyclic timing changing heavy advancement (heavy ping) to retarding (quiet). But I had no CEL (check engine light), codes displayed on the ScanGauge II, or unusual IAT temps. Till finally I tripped a code P0113 which I knew was a IAT sensor code and the display showed the -40*F for temp. But I reset the code and watch the display as a I traveled started seeing slightly off numbers you really have to watch the numbers closely and listen but you could see the number and timing rattle change up and down randomly till -40*F and CEL would pop... Well come to find out my IAT lead in my high idle fooler has damage somewhere so now to repairing my custom mod...
