Quad cab rear window detached at hinge
I would use 3m 5200 polyurethane adhesive, it's the best I have ever used, it's expensive at around 25$ per tube but it works,  I used it to reattach the latch part (not the hinge) to the rear side window, 8 years ago.  Clean up area to be glued good with acetone or similar but don't use a alcohol based cleaner as polyurethane  and alcohol don't play nice together.  I just checked you can get a 3 oz. tube for around 8$.  The stuff is truly amazing.  And no I don't own or have shares in 3m haha.
Edited by bcbigfoot
