Motor mounts
I need less booze in the egg nog...sorry. Im lifting the engine to drop the pan. The bolts are loose. The drivers side lifted right out. Passenger side wont budge. Do the "glue" themselves in. Is there a secret bolt somewhere? I did square up my lift so it is pulling dead even side to side.
  • Haha 2
You might have to unbolt the 4 from the block and remove the entire unit. Be careful with the engine hanging on the hoist 1,100 pound engine can do serious harm. Being you are enjoying the egg-nog be safe while your working! Might be a good time to pull them both and inspect them might be getting tired after all the years of holding torque.
