Does anyone know what fittings are available to make some new trans lines for my 47re..
AN fittings would be ideal as they are easy to get... What thread is the 47re and the trans heat exchanger ?? Thanks
  • Replies 8
  • Views 12.2k
16 minutes ago, Me78569 said:
an -08 if I remember correctly
That the thread into the 47re??
1/4 pipe I think.  you can find that on google.
On transmission case its 1/4 npt .   and on heat exchanger its 3/8npt  and one 1/2 npt   if I remember..   I put -8an lines on my 2001
so  2x -8an to 1/4 npt  ----   1x  -8an to 3/8npt   --- 1x -8an to 1/2 npt  ..    and fittings for cooler or coolers you use
I made it with  ptfe stainless steel braided lines .     easy to route and durable .     little  bit expensive!!     durable. its been 2-3 years  summer and winter driving.  no problems
Thanks for the replies everyone ive ordered 16ft of -8an nylon steel braid hose.
And 2x of every fitting mentioned above. I have the stock cooler that rubber pipe is clamped too so going to leave it as is just get rid of the stock trans pipes as they are a fortune to have shipped over.
