Need some opinions on setting wastegates
- Replies 14
- Views 5.8k
Greg Vance 6 posts
Dieselfuture 3 posts
NIsaacs 3 posts
Mopar1973Man 2 posts
Popular Days
No problem, only reason I knew about it, is, I have been looking at them because of the direct mount e-brake. I have also been looking at this one, it does have the 5 bolt adapter and is also a stock
I'd say tuning is the way to go, that's how my truck is set up at the moment. My wastegate hose is plugged off. I also don't use my wiretap at the moment, not that I couldn't I just don't see a point.
And that’s my question...does the extra fuel/heat create more horsepower or is it just extra “dyno power” for the big number on a piece of paper. At level 0 I can run at 100% throttle from 0-90+ mph a
So the beast is up and running like never before! This truck is very lively now..but I need some direction. I have many years in tuning and building imports, both NA and turbo applications, but wrapping my mind around the best way to run a diesel is proving to be a challenge.
Right now I’m running a pretty tight wastegate. I’m at or near max boost without wiretap. With the quad on level 0 it’s running about 30psi with the TC unlocked and about 35psi locked. On level 3 it’s about 33psi unlocked and 38psi locked. I’m limited to about 40-45psi with the K27, which builds boost so fast off idle it’s hard to tune for smoke...there is almost never any to tune off of!
So in your guys opinion, is it better to use the wastegate to set boost and limit fuel to keep from over boosting, or leave the wastegate loose and use fuel/wiretap to drive it to higher boost levels? Basically I’m smoke free at this point level 0-3 , just don’t know if there are any advantages to using fuel to drive wanted boost numbers or wastegate.
