Is their anyway to lower the rev limiter further down than 3200rpm?   Kinda like another security feature for when/if I loan the truck to someone and don’t want them to be romping on it.
Not really possible as the ecm is fueling if the quadzilla gives up control.  You could write a limiting table, but it wouldn't really work on multiple injectors
Use valet mode setting to limit power and set the tuner to lvl 1.   that will do exactly what you want it to do.
