I currently have a valve body that was "Professionally" rebuilt with a TransGo SK TFOD-Diesel shift kit. I had a single disk converter at the time. I understand that the shift kit has different procedures to follow whether you have a single or triple. I think this has to do with the size of hole drilled for the lockup circuit. Is there anything else?
I'm swapping in a Goerend 17SS triple disk converter, and a billet input shaft. If I leave the valve body alone, what can I expect? Am I in danger of damaging something? Is lockup going to be violent, or will it be manageable?
If I need to rectify this, what am I looking at? New separator plate? Plugging holes?
I'd appreciate any personal knowledge of this thrown my way. @Dynamic is a busy man, but I'm sure he'll chime in if he gets some spare time.
Edited by kzimmer
Typo
  • Replies 6
  • Views 3.1k
My best advice would be to call Dave Goerend since you are installing his triple disc converter.  He is a nice guy and can answer any questions you have.
I have his triple disc but also have his valvebody, billet shafts, billet internals, flex plate, deep pan, etc, etc, etc...which all came in a package.  I didn't have the pleasure of doing surgery on the valvebody so your questions are over my head. :think:
Be sure to do the W-T Ground fix if you haven't already.  Really smoothed my shift and Lock-up.  Plus it smoothed out my Cruise control, it used to Pulse like a Big Dog.  Was not comfortable.
Michael
Michael
I did my own ground mod a couple years ago, no issues. Any older vehicle I have owned, I usually upgrade the grounds.
I have to disagree with the ground fix smooth out shifting, unless you mean shift timing / back and forth shifting between 3rd/4th and lock/unlock.
I'm mostly concerned about if my lockup will be too violent with my valve body set up for a single.
My advise is to get a flax-plate if you have a stock one. Oftentimes the torque from lock up will rip the center out of the flex-plate, and you'll trash your transmission pump at the least, and the most destroy your transmission case as the TC spins around.
Yep. I broke my flex plate. That's why my trans is out right now. I am going to get a BD black oxide flex plate. Doesn't appear to be any damage to the trans but I haven't pulled the pump yet. The converter stayed in place, so I don't anticipate damage. I guess we'll see.
