Courtesy lights
Alright, I guess if I am going to spend some time on the truck this weekend maybe I should open this can of worms..  None of the courtesy lights in the truck work.  When I acquired the truck the previous owner said they were all fine until Best Buy put in the stereo.  Something they did screwed up the lights. Is this something anyone has heard of, or has an idea of where to start?
Thank You
1 hour ago, portlandareae28 said:
in the famous words of my children, "huh?"
Ignition Off Drain fuse.  I believe its under the hood.  Controls lights, and radio.  If those things are dead thats probably the culprit.  Had it happen to me on my Jeep.  Shorted wires going to the visor light and knocked out radio and inside lights and my power locks.
my radio works fine, you know what I can't recall if the mirror lights work in the visor, the map lights could have their own isolated problems I suppose, maybe it is just a dome light issue......  I will run out to the truck in a few minutes to check and report back.
15 minutes ago, Mopar1973Man said:
IOD (Ignition Off Draw) fuse is in the cab. Driver side fuse. The IOD is listed on the fuse cover.
fuse 17, and it is good
