Advice on 7x.010 race tune
GTC_Mopars
I've spent a long time lurking while I built my truck. It is "done" now and I'm working on tuning. I took it to a dyno a couple of weeks ago and datalogged two of the pulls. I made a race tune with the excel tune builder but I wanted to see what y'all thought and might have some input to squeak out a couple more torque and horsepower. It made 519.9 HP and 937.2 LBFT on the first pull and 519.9 HP and 910.8 LBFT on the second pull.
iQuad-Race Tune 7x10-2019-04-18-08.49.031114096596.json
Yeah sorry didn't realize how un-readable they would be when I saved them as an image. Hopefully these are better. Thanks in advance.
The truck is also making about 61-63 PSI but the MAP stops reading around 48-52 depending on the log.
Make sure your 30 psi stting it at %150.  Also Make sure your rpm setting is set to 3700 if you want to hold fueling longer.
You can likely use more wiretap as well, but thats only looking at the egt numbers.  It looks like a good towing setup though.
