Wiring diagram
Does anyone have a cab wiring harness diagram? I got a new led cargo light and the dang thing wont go off (clear only ) so I need to start tracing wiring to see what's going on... Diagram would be very handy :thumbup2:
Thanks!
Problem...
Cargo lights are a switched ground (pink/black) with a constant +12V (pink)
Brake lights are switched +12V (white/tan)... With constant ground (lt green/black)
If the LEDs have common ground then you stuck with what you got.
My idea is I'm going to use the factory lighting but switch then all out for LED bulbs. I've been doing the looking at the bulbs and prices.
