Just taking a little break from my TC Lock problem - which is still under study/investigation.
While digging around,
I found this black wire beneath the ABS module.
It comes out of the same wiring harness as the wires/connector for the ABS.
I rings out to chassis ground.  I assume a bolt/screw goes thru the eye, but I see no place
within black wires reach for it to go.
Does anyone know where it's home is please.
I bought truck second hand and it looks like the LEFT Fender might have been replaced.
Thanks.
Leaky
  • Replies 5
  • Views 1.7k
  • I think a lot of us have the same wire not connected.  No one has ever figured out where it goes and why, that I know of.   don't worry about it, or ground it if it pleases you.
  • On my '01 that wire is bolted/grounded to the ABS bracket.     https://www.turbodieselregister.com/posts/2418061/
HTH
Hag
The only all black wire on the ABS diagram I see is G100, and it does not appear to land in that area it's looks to be more up front on the left side.
There are 3 other grounds on the ABS sheet G101, G107, G200, they all have color tracers on the wire.
Is there a tracer on the wire?
Here are the locations of those grounds.
The manual is really great for all the info they provide on the wiring and harnesses.
G100, G101
92989173_Screenshot_20190713-190742_AdobeAcrobat.jpg.680d4f423a3c1b0e925c304f158d0ece.jpg
G107
831449796_Screenshot_20190713-185554_AdobeAcrobat.jpg.892fecd09b493e7f159a57f5958481eb.jpg
G200
1669419861_Screenshot_20190713-190132_AdobeAcrobat.jpg.a1be090bc2ad904828286305a681e9bf.jpg
Thanks. I went back out and verified there is no trace on the wire.  Just a black wire.
I took a couple more pics also. There are 2 branches coming off the Loom, 1 going to LF ABS Sensor, and one going
to the Proportioning Valve. And the mysterious Black Wire.
